top burners light but the oven will not ignite. It seems there is no gas for the igniter to start. I hear it clicking and trying to start but the oven does not come on.
You can't post conmments that contain an email address.
one potential solution if your Bertazzoni gas range oven can't be turned on is to check the thermocouple safety device, which is installed on every gas burner on the maintop and oven . If the thermocouple safety device is not functioning properly, it may prevent the flow of gas to the oven and cause it to not turn on. You could also check the gas flow issues if the outer ring of the burner ignites immediately but the inner ring takes a few seconds to light up.
If these solutions do not work, you may need to contact a Bertazzoni representative or a certified technician for further assistance in troubleshooting and resolving the issue with your gas range oven.
You will need to look and see if the igniter is glowing a bright red. If it is weak, the oven will not light. Here is the igniter if you need to order it. Also check and make sure your getting 3.2-3.6 volts AC to the valve.
I have the same problem with my whirlpool gas oven. The top burners work fine, but when we turn the oven on, the ON sign on the display stays on for about a few seconds and then goes away. The oven doesn't light up. Please help
Get the oven checked out by a professional, if you have a gas leak you can easily blow up the entire house and you with it. I think you have a faulty gas valve based on what you wrote
Sounds like the ignitor in the oven is weak and not building up enough resistance to the gas valve to allow gas to the burner. I would replace the ignitor if it is more than 3 or 4 yrs. old.
