Question about Poulan P4018 18Inch 40cc 2Cycle Gas Powered Easy Start Chain Saw With Case
Flooding want start(New Carb) - Poulan P4018 18Inch 40cc 2Cycle Gas Powered Easy Start Chain Saw With Case
  • 7,733 Answers
Give the chainsaw a break by turning everything off. Flip off the on/off switch. Turn the throttle off. Push or pull the choke to the off position and deal with anything else that might need to be switched off (off is the key word). Some even suggest removing the spark plug, pulling the cord a couple of times, then replacing the plug.
By doing all this you will make the saw (and you) more comfortable and start the process of clearing a flooded engine. Just as important, you've given yourself a minute or two more to recoup.
Flooding usually prevents a saw from starting. Flooding is the major cause of a stalled chain saw engine. Flooding is caused by too much gas applied at the wrong time. You need to prevent or remedy the flooding effect. The rebooting step (step #2) will improve this condition. Another suggestion loggers make is pulling the engine's cord through 8 times with all systems off. I don't know if this actually drains the liquid gas or gives a bit more time to counteract the excess liquid gas but I am assured it works. Do it 8 times!
Now. Set the on/off switch in the "on" position. The throttle "on" position should be turned on only as a last resort. Actually, I am told some late-model chainsaws specifically instruct you to tweak the throttle - so do it if instructed. Put the choke to the "on" position. The procedure in step #3 helps clear the engine of too much "liquid" gasoline. Again, putting down the saw down for a cup of coffee or soda will sometimes do the same thing.
OK. Everything should be back on..
Make sure you have the choke in the "on" position. When you do, pull the engine cord several times through until the engine "pops" one time. A pop is a quick audible response and **** by the engine without cranking. Please, NO more than one pop with choke on or you risk another fatal flood.
PLACE THE CHOKE IN THE OFF POSITION NOW!
With the choke in the off position, pull the engine's crank cord through again. The engine should start in 1 to 3 pulls. Try it first without using the throttle control (unless recommended by the manufacturer). Colder weather or a saw just out of storage can complicate these instructions. Here is further advice from an About Forestry Forum poster: "If I haven't gotten a pop in four pulls I transition to the part throttle, no-choke position and if I haven't gotten a start in maybe 8 pulls I return to the choke position for one or two pulls. I am sure this varies with different chainsaws, but you shouldn't have to pull very many times in the choke position, even in cold weather."
If you need more help come back.Post / thumbs / testimonial are welcome!
Posted on Nov 17, 2010
Anonymous
SOURCE:
I have a 1987 toyota 4x4 pickup carb truck starts up good but if u cut it off and let it sit for 10 or 15mins .it does not wont to start till u hold the gas pedle to the floor.?? help
carb ajustment is off--issues in the float causing it to flood--cud be sticking--get a haynes manual or library sec629 has shopbooks
Jan 14, 2015 | 1987 Toyota Pickup
I have a craftsman mower that will not start has spark getting gas may be flooding what may be the problem model # 944.369720
if flooding with gas replace needle and seat in carb take plug out pull starter cord to clear clinder make sure no gas in oil pull dipstick find out ok put the plug back in then squirt some starting fliud in carb start motor up
Sep 14, 2014 | Garden
Sthil 011 chain saw flooding has new carb
may be new carb but the main thing in flooding is that the float is getting stuck or has crack in it...Or second thing is that the needle valve has a piece of trash dirt causing it to stay open..
Jul 24, 2014 | Garden
Walbro Carb flooding 13 hp Kohler
the needle valve in the carb is not seating change the needle valve and seat also check the oil when this happens gas drains into the crankcase if so you will need to change that as well
Jun 28, 2012 | Garden
My rzt 50 mower carb. flooding when i try to start it
sounds like the needle valve in the carb is not seating change the needle and seat
Apr 27, 2012 | Mustang Garden
Briggs and stratton 5.5 lawnmower starts and suddenly stops. carborator flooding
I suggest that you start with the carb issue. Flooding is an issue with the inlet valve and float system. Get a rebuild kit and rebuild the carb. My bet is the unit will work correctly after that.
Apr 03, 2011 | Craftsman Garden
I've got a 2005 650 that is pouring gas out of a tube under the carb. It only pours when its started and running. Won't idle
Your carb has a hung float or needle and seat issues.
You have to take the carb off the bike and consider replacing the float and/or needle and seat.
You might get by just raising the float level. But this is only a stopgap maneuver. Buy a new float!
You bike is flooding so it wont run right until this is fixed.
The reason its only flooding while its running is because your bike has an automatic gas tank valve that opens when the bike starts and makes vacuum that opens the valve. It is saving you from the bike totally filling up with fuel!
Mar 07, 2010 | 2005 Yamaha V Star Classic
I have a yamaha trimoto 175 3 wheeler, The carb. Flooding!!
CHECK THAT THE NEEDEL IS NOT BENT AS IT HAS TO BE DEAD STRAIGHT .
Nov 08, 2009 | Yamaha YZ 125 Motorcycles
I have a 1991 cr250 wont start it has compression ,spark and gas to carb?? feels like it wants to kick over.problem started with having gas going thru carb was flooding , completely cleaned carb now wont...
just adjust the accelerator cable that is connecting to the fuel pump.check the and repair the throttle cause its the reason why it wont start . Its flooding the because of too much release of gas to the carb.
Jul 28, 2009 | Honda CR 250 R Motorcycles
Poulan P4018 18Inch 40cc 2Cycle Gas Powered Easy Start Chain Saw With Case Logo
171 people viewed this question
Top Poulan Garden Experts
roeb
dannydoesita
Marvin
Marvin
Are you a Poulan Garden Expert? Answer questions, earn points and help others
