The measuring cup holds 1/4 cup. Fill with tap water and pour one full measure into the hole exposed by removal of handle. Then measure table salt into small hollow on handle. Next, pour two (2) full measures of salt into a second measuring cup full of water, and pour into Sisan. Never use more salt than will fill the measuring hollow in handle. Remember that should the steam cease, unplug and refill with two measures of tap water, but no more salt.
Maintenance:
Add one (1) teaspoon white vinegar to two measures of tap water, put it in the Sisan Steamer and let it run a few minutes. Then pour this out of the Steamer and rinse well to scale the inside.
I can give you the salt measure but I need the water measure. Send me an e-mail at [email protected] with the water measure. The top of my unit says fill with no more than 2 measures of water and one salt. The salt is enough to fill the small opening on the top of the handle that seals the water in. If need be, I can send a picture.
stumbled on you guys...have the leaflet I can email/scan to you...I lost my measuring cup for water...can either of you tell me how much water the cup holds? [email protected]
did anyone find out how much a measure is...I bought a sisan steam smoother at a yard sale ( never been used) but the measuring cup is missing.
You can
definitely add salt and put herbs in the steamer. Try adding a couple of
bayleaves.
Instead of just using water, you can use a mixture of white wine or chicken stock.
