Intermatic T101 - 24 Hr. Dial Time Switch - NEMA 1 Indoor Steel Case - Gray Logo
Posted on Nov 17, 2010
Any idea where I can find a replacement for the "on" tripper?
  • Anonymous Apr 26, 2012
    You can purchase "trippers" (2 per bag) at Home Depot.
A
Anonymous
You posted under T-101 Intermatic timer.
T-101, T013, T-104 use same trippers.
If your model is different, add a comment.
Grainger sells T100 series trippers:
http://www.grainger.com/Grainger/INTERMATIC-Timer-Tripper-2E054?Pid=search
2answers
On/off tripper problem with T 103 timer
if it won't trip it, the on pin is not lining up right and u need to take it off and put it making sure it is right. if that's not it u got a bad timer
1helpful
I have a timer hooked up to operate my outdoor landscape lights so that they come on around dusk and turn off at 11 pm or so. The "on" tripper which is white clicks as the timer rotates past the...
Sounds like the OFF tripper is worn down.
Timer needs to be replaced unless you have Intermatic-brand timer.
Intermatic is only company that sells plastic replacement trippers for their timers.
Except Intermatic on-off trippers are typically red-green.
It's possible your trippers faded in color.
Open following links to identify Intermatic timer and tripper:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#appliance
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#trippers
I have an old "Intermatic Time-All." I no longer
Most time-all timers have two different trippers on dial.
Push down and rotate tripper to desired ON time and OFF time.
Then manually rotate dial until current time lines up with a mark or arrowhead.
To replace timer with new one:
Buy TN311c with 3 sets of on-off trippers that push onto dial, and 3-prong outlet.
http://www.amazon.com/Intermatic-TN311C-Heavy-Grounded-Timer/dp/B00002N5FO
Buy TN111c with 2 sets of on-off trippers, and 2-prong outlet
http://www.amazon.com/Intermatic-Appliance-Security-TN111C70-Settings/dp/B00002N5FI/ref=pd_cp_hi_3
I have 4 zones can run them manually; but they will not come on the automatic setting. Springs are strong; timer itself keeps accurate time. I did read inside the box about a "Silver Pin"...
If zones are not advancing, then 1) Clock motor is not rotating dial > replace clock motor, 2) on-off trippers are worn down > replace trippers, 3) or the day skipper is set to skip all days and all skipper pins are pushed down, 4) or sprinkler valve is bad.
The sprinkler timer dial rotates each 24 hours. The trippers cause sprinkler head to turn on zone 1 for example. Zone 1 waters until the dial rotates to part of dial with no tripper. Without a tripper on the dial, the timer turns off circuit to sprinkler. At this point, the sprinkler valve mechanically advances to zone 2 and waits for timer to turn off again. The timer does not advance sprinkler to next zone > the sprinkler valve is designed to advance each time circuit turns off. The timer just turns on and off. When next tripper rotates around, the timer turn on the circuit and zone 2 begins to water.
http://waterheatertimer.org/pdf/How-to-Set-and-Troubleshoot-Intermatic-sprinkler-timer.pdf
The silver pin inserted at 12midnight position is for advancing the day skipper wheel.
Open following link for parts and resources:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
HI , I would like to know what the red tripper represent "on" or "of " ?
The red tripper is ON.
Put trippers into dial, and then manually rotate dial to see how the lights turn on-off.
Rotate the round override switch and then rotate the dial again to see what affect the override switch has.
These actions will help you understand how to set power pack.
For replacement trippers and money-saving tips and useful troubleshoot information:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
My Intermatic sprinkler timer's 'auto" switch
You can replace the 133T1115A switch if that's the suspect part:
Other than the switch, the only other thing affecting timer would be the trippers.
I need a set of trippers for a Paragon 4001 switch timer. Need both "On " and "off" trippers. Can you find some?
Paragon 4000 series timers uses X2772 tripper
http://waterheatertimer.org/Paragon-timers-and-manuals.html
Google search x2772 tripper
Frontier Lighting shows they are out.
A couple other places show 56-60 dollars for the tripper
In November 2010, I got e-mail from Paragon saying that Paragon stopped making timers and parts for timers, except for defrost timers. 4001 is not defrost timer.
Intermatic has cross-reference link if you want to buy new timer:
http://www.intermatic.com/customer%20service/competitive%20cross%20reference.aspx
Cross reference shows T-101 timer matches your timer.
Aplus supply sells T101 for $60
http://www.aplussupply.com/intermatic/timer.htm
Amazon sells T101 for 43$ with free shipping over 25$
http://www.amazon.com/Intermatic-T101-Hour-Dial-Timer/dp/B00002N5FN
T101 wiring:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
2helpful
I HAVE AN iNTERMATIC t100m TIMER it appears to have two "off" tripper levers but no "on" tripper lever attached to the clock face dial by a set screw . Do I need an "on "...
Yes, the T101M 120Volt pool timer requires both ON and OFF trippers:
Grainger sells T100 series on-off trippers:
Amazon sells T100 trippers
http://www.amazon.com/dp/B003YO2C5U/?tag=picc-20
Grainger sells the T100 125V clock motor
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
How to wire T-101 120Volt timer
How Intermatic dial timer clock works.
Clock motor rotates dial.
Intermatic clock motor, located on back of mechanism, are replaceable
Trippers located on outer edge of dial push on-off lever
ON tripper pushes lever one direction
OFF tripper pushes lever opposite direction.
Lever pushes electrical contacts together and pulls contacts apart.
When lever moves, manual override also clicks back and forth with audible click.
To replace timer, replacement snaps into box without needing to changing box.
Top Intermatic Electrical Supplies Experts
Jay Finke
Jay Finke
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
Are you an Intermatic Electrical Supply Expert? Answer questions, earn points and help others
