Recently i faced this problem and fixed it without much difficulty. Neither format or flashing helped. just follow the steps explained at http://chandanguptafix.blogspot.in/2012/...Recently i faced this problem and fixed it without much difficulty. Neither format or flashing helped. just follow the steps explained at http://chandanguptafix.blogspot.in/2012/06/nokia-7210-supernova-not-enough-memory.html
You can't post conmments that contain an email address.
maximum free space requirement reach,that's why no matter how erasing some files,it is not possible because system is already corrupted.
To fix this problem,
* go to settings > phone > then restore factory settings,now choose to reset,it will ask for the lock code,enter the desire lock code or type 12345 for the default code,then the phone restart automatically. Now you phone is on original settings,then start playing music.
Note : This will delete all data stored on you phone,so back up all important files before doing this method.
Not Enough Memory error suggests that you dont have enough space to load the program into the Memory. Check Phone's Memory (It is about 30 MB total) if there is stuff in Phone's Memory then shift it over to Memory Card and cleanup the space in Phone's Memory. It will definitely resolve this issue. If even after wiping stuff from Phone's Memory doesn't work, reset the phone.
I HAVE TO PROBLEM:- " NOKIA 7210 SUPERNOVA" ...... PLZ HELP ME...1. when i open my music player it shows "not enough memory"2. I FORGET MY SECURITY PASSWORD, SO I DONT USE RESTORE OPTION ,I HAVE ALSO USE MASTER CODE, BUT IT ALSO DONT WORK ON MY MOBILE.... Anil Yadav
your phone memory is about to full.you should move some items from phone memory to memory card untill this problem presist.after this updating library automatically started.after updating your music player work. & you should reset phone.after reset phone will started with default configuration it can recover your themes etc...
phone memory has limited space.if phone memory is about to full.this type of problem occur.you should move some item from phone memory to memory card.after that go to music menu.selects options>update library.after updating press ok.your problem will be solved.
& for software problem you should reset the phone
phone memory has limited space.if phone memory is about to full.this type of problem occur.you should move some item from phone memory to memory card.after that go to music menu.selects options>update library.after updating press ok.your problem will be solved.& for software problem you should reset your phone
Perform a full backup of your phone using nokia pc suite then restore this backup to your phone after the phone restarts you should have no more problems with the music player
