Most computers have power saving modes that automatically turn off the machine when it's not being used to save energy. You can modify those power saving settings to keep your computer on at all times, or increase the time it takes to 1) make the screen go black, 2) put the computer in a sleep mode, 3) put the computer in a hibernation mode (deeper sleep mode) or 4) Power it off completely. Those modes depend on your PC type of course.
Press the Power key > Activate power saving. To deactivate power saving mode, press the Power key > Deactivate power saving.
When activated, the power saving mode turns off some functions automatically. Radio configuration in power saving mode include the cellular radio (it is set to 2G/GSM only mode), the Bluetooth radio (it is turned off) and the Wi-Fi/WLAN radio (scanning for new networks in turned off but existing networks keep functioning). The power saving mode also reduces display power consumption by minimizingscreen brightness and by turning off touch screen feedback and theme effects. In addition the vibra alerts are turned off in a power saving mode. Hope that helps Anomy.
Hi, the Power Saving Mode, turns the screen off to conserve energy. On the remote, press Menu, and scan to Power Saving Mode. You can change the amount of time, when the Screen turn-off, the TV shut-off etc. You can set the time to (5 min) to, (never, turn-off). This should help with your problem. Thanks paul7of9
If mbase213's solution doesn't work, try the solution I've found in another forum. Read through the whole thread.
http://en.kioskea.net/forum/affich-46233-can-t-exit-power-saving-mode
Check the power setting in control panel of windows. If you have a monitor from another computer swap them and see if the problem stays with the computer or monitor.
Hold down the 0 and 8 keys while turning on the copier. Keep on holding down the keys until the screen shows a adjustment mode screen. Once it does this key in 205 then you should see a numeric value. Input 15 and press start to lock it in This will change you power saver mode to 60 minutes. Next enter code 206. Key in 19 and press start. This will change your sleep mode to 240 minutes. These are the setting that are most generally used when these copiers are initially set up. Then just turn the copier off and back on. I hope this resolves your problem.
Hi there The computer is going into power save mode, to resolve this go into the control panel and choose power options, set all the options to "never" and save, the monitor will now stay on while you watch your video's
its because it has gone into power saving mode, you need to go into the power/battery settings and set the brightness at 100% and then choose that setting as default.
