F14 Scanner unit FROM error
Was the main PWA replaced?
YES
Download the scanner total count value into the main PWA in the setting mode (08-388).
NO
Was the scanner unit or scanner control PWA replaced?
YES
Download the scanner total counter value of the main PWA into the scanner control PWA in the setting mode (08-389).
NO
1. Check if each connector between the scanner control PWA (CN6) and the main PWA (CN8)
is disconnected.
2. Check if each connector pin is removed or the harness is broken.
3. Check if any conductor pattern on the scanner control and main PWA is open- or shortcircuited.
4. Replace the scanner control PWA.
5. Replace the main PWA.
Toshiba E207 Photocopier Machine Call for Service F14 error Switch off the machine Press and hold 08 while switching on the machine 'Test Mode' will be displayed Press 389 and then press start button Switch off the machine Switch on the machine The machine will work properly.
YES
NO
YES
NO
is disconnected.
Hey friend, thanks for your post!
I see that your Electrolux wall oven is displaying an "F14" error code. "F14" stands for display tail missing, which means you could have an issue within your main control board or keypad. I would perform a reset on your appliance which can be done by flipping your household circuit breaker off for roughly ten minutes. If that does not correct the issue I would suggest seeking a professional to come out properly diagnose and repair your appliance. I hope this is helpful. -Matt
