My printer is printing horizontal black lines over everything??? Help!
My printer has never had a problem....
But today it started prinitng over my documents a horizontal black lines about a 1/4" in diameter.
Any suggestion????
Thank you!!
~Ophelia
Re: My printer is printing horizontal black lines over...
Restart the printer and the computer.
This might be a problem because your data cable is not fully inserted into the computer/ and or the printer.
Make sure that it is connected fully.
Push menu on your printer, then fin maintainance. Then go to clean printer and push the green button. It will clean the cartridges for you and that should help.
Seems like the drum needs changing. This is the most common cause for print problems in these printers. If using the high yield TN 6600 toner then you need to change the drum every 3-4 toners. If using the low yield TN 6300 toner then the drum will need replacing every 6-7 toners. Hope this helps
try to perform maintenance of your printer on the setting and open your printer clean up the nozzle use alcohol and cotton buds and then placed it back properly!!
Have you tried updating the printer driver (first uninstall the existing driver and make sure you have the latest one already saved to your PC before starting). I don't think your current one has mysteriously misbehaved, I suspect that it has been corrupted in some way (a new download may have done something to a critical part of the driver).
By deleting and re-installing you are "refreshing" everything.
there are like broken lines running down my printed documents
My Brother Printer keeps printing black lines down my documents.
