Washing Machines Logo
Posted on Nov 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have the 2010 Samsung Washer/Dryer 10kg and it is stuck on child lock. I can not get it off. Help?
Anonymous
Level 3:
Genius:
  • Master 1,672 Answers
  • Posted on Nov 17, 2010
Anonymous
Master
Level 3:
Genius:
Answers
1672
Questions
0
Helped
461776
Points
5030
Follow this instruction............. ACTIVATING/DEACTIVATING
If you want to activate/deactivate the Child Lock function, press the Soil Level and Signal buttons at the same time for 3 seconds.
How It Works: 1. "Child Lock" can be activated while your Washer is running. 2. Once you activate "Child Lock", all controls (except for the Power button) will be locked until you deactivate "Child Lock". 3. The Child Lock button will be lit while it is in effect. When buttons, other than the Power button, do not respond, please check if the "Child Lock" function is on.
Hope this helps u out!
How do i unlock child lock on defy 10kg front loader machines, steam cure. I've tried press and hold SPIN and TEMP button also START/PAUSE button for 5sec but still nothing is happening
Here you are;
https://www.google.com/search?client=firefox-b-d&q=child+lock+on+defy+10kg+front+loader#kpvalbx=_f36RZezPOpiHhbIPg6uqgAY_35
1helpful
2answers
My Samsung washing machine keep showing child lock sign even door is open, but machine doesn't works either. anyone got any suggestions. thanks
The child lock is sometimes called the control panel lock. This keeps the washer from starting a program while cleaning the washer or when a child presses the buttons.
To toggle the child lock on and off, you need to press and hold two buttons simultaneously for three seconds. These buttons will be indicated by a line between the two buttons either Child Lock or a smiley face in a padlock symbol in the middle of the line. The symbol or the words will be in a very small font.
On some Samsung washers, press Temp and Spin or Temp and Rinse. On the WW7500 models, press and hold Options and Smart Control. For other models, see https://www.samsung.com/uk/support/home-appliances/how-do-i-switch-the-child-lock-on-my-samsung-washing-machine-on-and-off/ .
I hope this helps. Please add a comment with the model number of your washer if you still can't find how to toggle the child lock off.
3answers
Error code CL9 on Samsung dryer model DV48j7700EW/A2 POWERS ON, WONT RUN, AND WONT HEAT.
I can't find anything online about error code CL9. Even the owner's manual does not list that error code.
https://www.searspartsdirect.com/partsdirect/user-manuals/dv48j7700ewa202-samsung-parts-manual
1helpful
Hi,I have lost the user manual for my samsung front loader washing machine IPX4 model www60j426hs and the lock sign stays on. It is stuck and cant change programme. What can I do?
seems as if the washer is in child lock mode pressing and holding a key related to the child lock for four seconds will unlock the washer and allow you to use the washer again
I am trying to start my washer and the symbol of a head with a collar appears on the dial and i am unable to change any of the controlls or start the washer.
Hi.
Samsung machines error codes are numbers and letters, then I the machine is not in fault mode, but child lock has likely kicked in.
Here is child lock icon:
Try the following:
How It Works:
Here the user manual.
6helpful
Child lock is stuck on and athe dryer will not turn on. How do yoiu turn off the child lock?
HI!!
Child Lock can be used to prevent your children from undesirable use on control panel while the dryer is running. When Child Lock is enabled, all the button will be locked and Child Lock glows. To lock Child Lock, Press and hold Rack Dry for 3 seconds, A single beep tone is heard and CL is displayed on the status window. To unlock Child Lock, press and hold Rack Dry for 3 seconds again.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
9helpful
2answers
Cant disable child lock
The child lock on my Bosch Logixx8 washer has come on and i need to disable it
Child lock flashing and cant use machine
Press and hold the child lock button for at least 3 seconds.
This should reset the washer to normal use.
Plz rate my solution.
Thankyou.
Top Samsung Washing Machines Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
