SOURCE: I AM TRYING TO SET THE DATE & TIME TO APPEAR ON MY PHOTOS.
you can only do date and time stamp under function button go to bottom where you can change size of pictures -go to right to W or wide-this is only setting you can do date time stamp on-when you change pic size and go back to menu you will see it highlighted and you can now turn it on-equals about a 2-3 megapixel size picture only-also just leave settings alone and have printer add it-date and time our always in pic data and most printers can add it
SOURCE: Canon SD 1000 time and date stamp on downloaded photo
You can download the manual from the link below: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=323&modelid=14901 From page 37 of the manual it looks like you can only select the time stamp in "postcard" mode. Also the date & time need to be set in the camera first. Please update the question & let us know if the information given was useful to you - Good Luck!
SOURCE: I cannot get a date
In order to get the date stamp on the pictures, the resolution/size has to be set to "Postcard". Look at the menu and you will see L, M1, M2, M3, S, and Postcard. Then you can turn on the date stamp option.
SOURCE: cannot turn date stamp on in menu settings.
Date stamp is only possible when you set the resolution (picture size) at "Postcard 1600x1200" option, if the date stamp is set to "Date & Time" or "Date" option
SOURCE: i have a canon powershot
When you turn your camera on, there is a screen which appears in the viewfinder. Push the FUNC SET button and then scroll down the column on the left of your viewfinder until you come to the one with the letters M1 M2 M3 S, etc to the right. Then select the one called "Postcard 1600x1200" by scrolling to the right. Your camera is then in the post card mode. You can then go to the date stamp in the menu and your camera will not skip over it any longer! EUREKA!!
