Heating & Cooling Logo
Posted on Nov 17, 2010
I have life smart infrared heater 1500w. when power source on. turn power button on and set temp. unit runs and blows warm air for about three to five mins then shuts off. can restart with power button but then does same thing
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 13, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
4346
Points
5
The thermostat needs to be replaced. The Company sent the replacement part for free. The also said they would send the instructions to fix it, but they did not. I am looking for instructions online. ;-(
2answers
Heater temp on high only bows luke warm air after driving. A/C works just fine.Plenty of cold air from it
heater blows cold air idle chrysler 300 Questions & Answers ...
www.fixya.com > Forum > Tags
Find solutions to your heater blows cold air idle chrysler 300 question. ... blow warmair for a few mins then back to luke warm. i replaced thermostat ... HEAT BLOWSCOLD AIR WHEN IDLING ONLY GETS HOT WHEN START DRIVING ... About 15 minutes after driving the diver side vents start blowing straight cold air but the ...
Heater only works when pressing the gas? - DoItYourself.com ...
www.doityourself.com/...repairs.../459521-heater-only-works-when-pres...
Nov 3, 2011 - When I press the gas, the air from the vents is nice and hot. .... So am Idriving a car with a ton of problems, or could the power steering ... Just anotherquestion, when warmed up does the engine temperature ... When the heater is on and I'm not pressing the gas pedal, luke warm air blows from the vents.
Heater blows cool air when stopped and warm air while ...
https://www.reddit.com/.../heater_blows_cool_air_when_stopped_...
RedditFeb 12, 2014 - Heater blows cool air when stopped and warm air while driving 2008 Kia Spectra (self. ... just fine but appears to blow cool air when I was stopped at a stoplight. ... My temp gauge would also be pegged high when at idle / low RPM. ...thermostat only blocks coolant going to the radiator, and the heater core, ...Missing: 300m ‎luke
Why is My Car AC Blowing Hot Air? - BlueDevil Products
gobdp.com/blog/car-ac-blowing-hot-air/
Tips on how to fix a Life Smart LS-500-1PC Infrared Heater
The above fix is NOT for a Life Smart LC-500-1PC.. this is Life Smart LC-500-1PC. http://lifesmartproducts.com/current-products/infrared-heaters/52-2011-products/332-ls-500-1pc.html
Sounds like the thermostat is out. Order one, and hope it comes with a repair manual!
2004 Odyssey, heat and A/C do not work unless van in motion
Since warm air eventually comes out when the vehicle is in motion, you may have an air mix door that is stuck in fresh or is somehow blocking warm air from the heater core.
To see if the air mix control motor is bad, you need to retrieve your Diagnostic trouble codes (DTC's) from the heater control panel. To run the diagnostic function, do the following:
1. Turn the ignition switch ON (II).
2. Turn the fan switch OFF.
3. Press the recirc control button to select Recirc (recirc light on.)
4. Press and hold the recirc button to select Fresh (recirc light off) and continue to hold the button down until the recirc light comes on for two seconds and then goes off.
5. If the system is okay, the recirc light stays off.
6. If there is a problem, the recirc light blinks the DTC to indicate the trouble. One blink=a problem in the air mix control motor circuit. Two blinks=problem in the mode control motor circuit
Three blinks=problem in evaporator temp sensor circuit.
7. Turn the ignition switch off to cancel the self diagnosis function. Run the diagnostic again after repairs are complete.
Note: the air mix control motor has a rod which connects to a plastic link. The link controls the mix doors and also connects to the heater control water valve via a cable. The air mix motor may check okay, but if the link is broken then you will still have problems. the motor is on the bottom of the heater unit in the front passenger's foot well.
1helpful
Central Electric heat not blowing hot or warm air
Make sure you are in the heat mode. Do you hear the wall thermostat click when you raise and lower the set temp. If not replace thermostst. Clean all filters to start. Does your heat source have a pilot light to start or is the unit located out side. If apilot light make sure itis lit. let's go from there
[email protected]
I have a Rinnai Energysaver 556F
The heater will have some error codes stored in it. To retrieve them get an assistant to write down the codes as you see them. They come quickly. OK to get the codes, push down on the Economy button and the up arrow and down arrow at the same time. Hold for three seconds. It will take three fingers to do this. Once you get the error codes, look in your owners manual to diagnose.
Top Heating & Cooling Experts
Paul Carew
john h
