Master
- Posted on Nov 17, 2010
Re: KitchenAid KESC307HBT4: Oven/Broiler/Convection...
There is a problem with the power going to the relay try to check if there is a fuse before the relay. If you have voltmeter try to get the voltage reading on the supply terminal of the relay. If there is a voltage going to the relay, then the relay is the problem . Replace it with same value.
