Technics SL-1200MK2 Turntable Logo
Posted on Nov 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
One channel on my sl1200 mk 2 has very minimal sound out put. I have to turn my balance selector on my reciever almost full right to balance the volume. Any insight to this problem is appreciated. Anthony
mwarej123
Level 3:
  • Master 454 Answers
  • Posted on Nov 16, 2010
mwarej123
Master
Level 3:
Answers
454
Questions
Helped
180103
Points
1400
As a test, switch the right and left RCA cables from the turntable to the amp. If the problem reverses, the issue is in the turntable or with the cables. If it stays the same, its a problem with the amp.
How do you balance sound between two speakers. Where is the balance control? JVC RX5000v
On the front panel ONLY:
1. Press ADJUST so that the MULTI
CURSOR up/down buttons work for
adjusting the sound.
2. Press MULTI CURSOR up/down
repeatedly until "BALANCE"
appears on the display.
3. Press MULTI CURSOR left/right to
adjust the balance.
• Pressing left decreases the right channel
output.
• Pressing right decreases the left channel
output.
please rate my solution.
2answers
I have two 1210s, a mk 2 and a mk 5. When I let go of a record on my mk 2 it seems to take longer to catch speed compared to my mk 5, and feels 'slack'. Any ideas what this is?
Being the older model, the chances are that the drive belt on the Mk2 turntable has got worn and shiny with use. It may also have stretched a bit. If you are using the tables for 'scratching', the fact that you are holding onto the turntable when the motor is running is placing a strain on the belt that it is not really designed for. I would recommend changing the belt - you can easily find spare belts for sale on the internet
2answers
My cb cobra 29 ltd problem is channel 1 is ok but channel 2 not receive
Did you have someone get on channel 2 to see??? Maybe channel 2 was quiet and channel one had better receive or noise.. You never know until you check it with another radio. That is NOT a common issue at all on those radios. Better off doing that test.
"WILDCAT" IN LAURELVILLE OHIO
35 YEARS OF CB FUN!!!
1helpful
How do you perform a full reset on a kenwood tk-370
Field Programming procedure for the Kenwood TK-270 or TK-370 handhelds. Press and hold (light) & (dial) while turning on radio. Hold until (SEL) appears on the display. Pressing (SCN) allows you to program the following 1. Monitor Key Off = off 1 = Monitor momentary 2 = Monitor Lock 3 = Squelch off momentary 2. Scan Key Off = off Co = carrier operate To = Time operate 3. Dial Key Off = off On = enable 4. TA key TA = talkaround RV = Reverse Off 5. Lo Key On Off 6. Priority None 1 = fixed 2 = selected 7. Fixed Priority Channel Turn selector to channel 8. Look back time A Turn selector to time in seconds 9. Look back time B Turn selector to time in seconds 10. Revert Channel 1 = Selected 2 = Last Call 3 = Last used 4 = Selected + Talkback 5 = Priority 6 = Priority + Talkback 11. Tx Dwell time Turn selector to time in seconds 12. Drop out delay Turn selector to time in seconds 13. Time out timer Turn selector to time in seconds 14. Tot Pre-alert Turn selector to time in seconds 15. Tot Rekey time Turn selector to time in seconds 16. Tot reset time Turn selector to time in seconds 17. Squelch Level Turn selector to Squelch 18. Beep tone On Off 19. Signalling And Or 20. Battery Save On Off 21. Selectable QT On Off 22. Clr to transpond On Off 23. Del/ Add On Off Pressing (Dial) allows programming of: DTMF 24. digit time Turn selector to time in milliseconds 25. inter digit time Turn selector to time in milliseconds 26. First digit time Turn selector to time in milliseconds 27. Rise time Turn selector to time in milliseconds 28. Rise time with QT Turn selector to time in milliseconds 29. PTT ID Off 1 = connect 2 = disconnect 3 = Both 30. Dial ID On Off 31. Connect ID 32. Disconnect ID 33. # of DTMF keys on Keypad 12 16 34. DTMF hold time On Off 35. Store & send On Off 36. D key assignment Turn selector to D or time in seconds for pause 37. Dtmf Signaling Off 1 = code squelch 2 = Selective Call 38. Intermediate Code OFF A B C D E F 39. Group Code OFF A B C D E F 40. Auto Reset time Turn selector for time in Seconds 41. Call Alert/ Transpond Off 1 = 2 = 3 4 5 42. Transpond On Off Pressing (TA) will allow you to program Frequencies Use selector to choose channel Press PTT Enter Rx frequency using: - the Selector Knob to change kHz; - the Selector Knob + (light) to change MHz. If no channel is Shown press the (LO) button. Press PTT Enter Rx CTCSS code Press PTT Enter Tx Frequency as above Press PTT Enter Tx CTCSS code Press PTT 1. Option Signal Off 1 = DTMF 2 = 2-Tone 2. PTT ID On Off 3. Add/ Del 4. Busy Tx 5. Clock frequency shift 6. Power Hi Low Repeat for the other channels (you've got a 32 channel radio, so it may take a while...) <end>
4helpful
2answers
Right front channel not working
try to check balance adjustment if working.
1helpful
MK Sub woofer to Denon AVR
you caan either buy a SPLITTER OR JUST RUN A SINGLE LINE OUT OF THE RECIEVER INTO THE SUB. BOTH DONT NEED TO BE PLUGGED IN. SUBS ARE MONO NOT STEREO. THERS NOD IFFERENCE IN SOUND
Nad C320 right channel stops working then comes back again
This sounds like the "pre-amp" section is cutting out or there is some interruption in the signal path. A few things to try:
1) With the unit off, try "working" the volume,balance and tone controls. This means, turn them up and down a number of times to clear any debris that may be in the controls themselves.
2) Work the input selector switch the same way if it is a rotary switch.
3) Try turning on/off the tape monitor switch a few times.
4) Keep track of whether this problem is sensitive to heat. Does teh channel shut down more quickly once the unit has been on for a while?
Lastly, if you can solder, look for any solder joint that appears grainy or has rings and resolder it.
Update this with your results and we'll continue on...
Thanks,
Dan
Harmon Kardon and Infinity Modulus
I got the answer for No-1.
The balance was turned on the Right Channel. That is why Left Channel was not working during the Channel test.
For Channel test the Balance should be in the middle so that both Right and Left Would be heard.
I am working on my Subwoofer Isuue.
I opened the Back Panel and Yet I could ot figure out any issues.
I will open the front panel and see if any connection is loose.
Improper function
try hooking up your subwoofers in series. then connecting them bridged to the amplifier. as follows: positive from sub#1 into positive of amplifier left channel.. negative sub#1 into positive sub#2. negative sub#2 into negative amplifier right channel. turn the gain down as this will sound pretty loud.
Technics SL1200 MK II Speed problem
this one happend to me!! try taking the plastic cover off, under the platter and removing the screws that hold it on if that cures it its because what you ll find is that the screws just catch the underneath of the platter as it rotates. happy mixing
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
