Televison & Video Logo
Anonymous Posted on Feb 15, 2018
Copy tape to dvd using Q-VHQ 760 & Pinnacle instant dvd recorder. Playback looks great, unfortunately there is a thin fuzzy line at the bottom which never changes. My question - how can I fix this ? Looks like a tracking problem, but no tracking adjustment on this unit. Any ideas ?
Lawrence Oravetz
Level 3:
  • Quasar Master 10,558 Answers
  • Posted on Feb 15, 2018
Lawrence Oravetz
Quasar Master
Level 3:
Answers
10558
Questions
Helped
2700225
Points
29284
Check the edge of the tape to see if it's wrinkled. That is the most common problem that shows that line. You may be looking at the head switching pulse too. Since your VCR has no tracking adjustment, it has to be done with special tools, an oscilloscope and a voltmeter. Not an easy task.
1 Related Answer
Anonymous
  • 10594 Answers
  • Posted on Jun 10, 2010
SOURCE: im looking for a manual for my video recorder
Click HERE to download required user manual of Panasonic VHQ-41M
Thanks.
I'm capturing video from a Sony DCR-TRV27 Mini DV Digital Handycam. The original tape is crystal clear with great color on our 1080 flat screen. The captured video is fuzzy, color washed out, a serious...
Welcome to Fixya,
What is the Pinnacle capture device when you try to capture the video? Is that 500-usb or 710 usb? What is the Pinnacle program did you used? Need to know it before we proceed
IUSED MY DAZZLE DVD RECORDER MANY TIMES BUT
Please check this link http://pinnaclesys.com/PublicSite/us/Products/Consumer+Products/Home+Video/Studio+Plug-Ins/Instant+DVD+Recorder+Support/Download+Area/Drivers+-+Updates/IDVDR261.htm?mode=documents&Display=1 that is for the instant DVD recorder program you can download and install that to your computer. Now if you need Studio program just call Pinnacle customer service and then asked for the replacement disc for $14.95 only.
1helpful
Transfer my vhs tapes to dvd
Please check this link ftp://ftp.pinnaclesys.de/Manual/InstantDVD_Recorder/Instant_DVD_Recorder_ENG.pdf
That is the manual for your Instant DVD Recorder try to do the procedure.
VHS copy to DVD
Just to verify what program do you want are you using the studio or the instant dvd recorder? So that I can guide you to the rest.
No video in dazzle pinnacle
Please try to copy the link below to your URL: this might help you to isolate the case.
Answer Title: No video displayed in the Instant DVD Recorder preview window
Answer Link: http://pinnacle.custhelp.com/cgi-bin/pinnacle.cfg/php/enduser/std_adp.php?p_faqid=18309&p_created=1227727003
1helpful
Having a hard time connecting various audio components
Yes, it is a little tricky...
1) CD Changer (output) -> CD input on Amp
this is tricky... this will allow you to record to your tape deck, and control the sound via the EQ:
2) Tape Deck (tape out / recout) -> TAPE PLAYBACK on EQ
3) Tape RecOut on EQ -> Tape 1 Playback on Amp
4) Amp Tape 1 RecOut -> Tape Deck Playback / Input / RecIn
in essence, your creating a loop starting from the tape deck, going to the eq, then to the amp, then back to the tape deck to record.
Your EQ has another set of LINE IN and LINE OUT - use the second Tape 2 on the amp to create another loop. This will
allow you to control the EQ for any of the other sources.
5) LINE IN on EQ -> Tape 2 RecOut
6) Tape 2 Playback on Amp -> LINE OUT on EQ
5) Radio Tuner (output) -> Tuner input on Amp
6) DVD/VCR Combo Output -> AV/AUX on Amp
7) PC Computer... you don't have room for this. You can either use the PHONO input, and you'll have to purchase a Line Level Phono Converter
or, get a Y cable and split the signal and share with some other source.
Hope this helps.
- OPTiC
www.djproaudio.com
www.repairny.com
Panasonic DMR-EZ47V Fuzzy horizontal line in VHS mode
Dirty heads or the recording was from a different brand VCR and the Panasonic cant get the right tracking. Try manual tracking just a little in either direction to you get the right one.
14helpful
8answers
Dubbing vhs to dvd
Easy. Connect RCA lead from video/audio OUT on the VCR to video/audio IN on the DVD recorder. Set DVD recorder source to VIDEO then press play on the VCR and record on the DVD recorder.
Top Quasar Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Quasar Televison and Video Expert? Answer questions, earn points and help others
