Have you done a factory reset or just a reboot?
Login into you router using your browser (connected by a LAN cable) and under the wireless section you should see the network password.
The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can ssets-up form scratch.
SOURCE: I can't reset my router.
for default login and password, http://purelypc.blogspot.com/2008/04/default-logins-and-passwords-for.html
SOURCE: CAN NOT OPEN DEFAULT USER NAME / PASSWORD, ADMIN/ADMIN
On the back of the device, There is a small reset button, Hold that with a pen for 30 Seconds, that will reset everything, Including that password.
SOURCE: can't access D-link DI-614+ as admin
Direct from the D-Link FAQ's
This reset procedure applies to the following devices:
DI-704
DI-704P
DI-713
DI-713P
DI-714P+
DI-804HV
DI-808HV
The unit will reboot itself and should be at factory defaults. If the M1 light is not blinking about once per second, recycle the power on the gateway.
If the M1 & M2 continue to blink rapidly, you held the reset button for too long. Power the device off and repeat the reset procedure.
The default IP address is 192.168.0.1. The default username for our routers is admin. The password is blank. If your router asks only for a password, use admin (lower-case).
The following reset procedure will completely restore the default settings on your D-Link device including your password. This procedure applies to the DI-514, DI-524, DI-604, DI-614+, DI-624, DI-754, DI-764, DI-774, DI-784, DI-804V, DWL-700AP, DWL-800AP+, DWL-900AP+, DWL-1000AP+, DWL-2000AP, DWL-2100AP, DWL-6000AP, DWL-7000AP, and DWL-7100AP.
Note: Do not recycle power during the reset procedure.
The default user name for most D-Link devices is admin and the password is left blank.
When it says hold for about 10 seconds, don't hold for more than ten seconds or the procedure will likely fail, if ten seconds doesn't work try 5 seconds.
P.S.: If this information was helpful, please rate this solution.
SOURCE: LOGIN FAIL
at the back of the router is a tiny hole, so while router is on and working push the paperclip or something inside and hold for at least 10secs. This step will reset the router to factory settings and you'll be able to login again
SOURCE: I can't change my wireless
Try admin, admin. If no success, go to D-link and download manual, press reset button on the router for 30 sec. And reset the settings, remember to change and record: system id, access password, wireless security, wireless password.
Testimonial: "Great advice, worked in 3 seconds, many thanks!"
