Question about Canon Rebel XT / EOS 350D Digital Camera
Err 99 - Canon Rebel XT / EOS 350D Digital Camera
    New Friend:
    Problem Solver:
  • 14 Answers
ERR99 itself is Canon unknown error code
In ERR99 40D is shutter problem, but in other machine ,
so far, it could be a battery, lens contacts and so on many issues.
If not frequently ERR99, you can't go find Canon maintenance, because their that if did not appear to ERR99 he also can find no way out. And even if appear, he may not give your diagnosis again.
Better take to maintenance center to check! If the warranty period gone that is a little trouble.
Canon Digital Rebel XT / EOS 350D Digital Camera battery
http://www.camcorder-batteries.us/digital-camera-batteries/canon-eos-350d.htm [usa]
http://www.my-battery.co.uk/digital-camera-batteries/canon-eos-350d.htm [uk]
Posted on Nov 16, 2010
  • 10,865 Answers
Hello hemantp. This error code in this model indicates that the lens electrical contacts are dirty or slightly oxidized. To clean them you will need a common pencil with a clean eraser on the end and a lens cloth.
Detach the lens from the camera and hold it so that the lens' gold contacts are pointing down. Lightly "erase" their exposed surfaces and then clean them with the lens cloth to remove any debris.
Do the same with the gold contacts inside the camera body. Although this is a wee bit more challenging, you can do it by holding the camera so that the lens opening points down. That way no debris will fall inside as you clean. Joe
Err 99 message on canon 450d
CANON ERROR 99 1. Turn off the camera. 2. Remove the lens, battery, and CF card. 3. Allow the camera to sit without power for approximately 20 minutes. 4. Insert a fully charged battery, and turn on the camera. 5. Depress the shutter button as you would to take a picture. Does the "ERR 99' message appear? If it does, then the camera should be serviced. If it does not, then please proceed to the next set of steps: 1. Turn off the camera. 2. Insert the CF card. 3. Turn on the camera. 4. Format the CF card in the camera. 5. Depress the shutter button as you would to take a picture. Does the "ERR 99' message appear? If so, then the CF card is the most likely source of the issue. Try using a different card. If the message does not appear, please complete the following steps: 1. Turn off the camera. 2. Clean the lens contacts by gently rubbing them with a pencil eraser or soft cloth. Be careful that you do not let any debris fall into the camera body. 3. Reattach your lens. 4. Turn on the camera. 5. Depress the shutter button as you would to take a picture. If the "ERR 99' message only appears when one particular lens is attached, then that lens should be examined by a service technician. If you see the "ERR 99' with a different Canon lens attached, then the camera should be serviced. http://www.youtube.com/watch?v=WkXyLieNUDI - - - - - VIDEO & VOICE INSTRUSTION. Error 99
Aug 12, 2012 | Canon Cameras
I have err 99 any solution?
.1. Turn off the camera.
camera body.
Jun 08, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Err 99 keeps coming up
It is due to some kind of electrical (contact) failure.
For more details and common causes of Err 99 read the following article:
http://www.lensrentals.com/news/2008.12.31/canon-err99
May 16, 2010 | Canon EOS 40D Digital Camera
I receive Err 99, it says to re install battery or
It is due to some kind of electrical contact failure.
May 14, 2010 | Canon EOS 40D Digital Camera
Canon EOS Xt displays Err 99 how do I fix it.
change the lens or try cleaning the connector tabs with a eraser.
Jun 26, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Rebel XS ERR99
This is something I found when googling your problem.
Thank you for contacting Canon product support. I'm sorry to hear that
your EOS 10D is displaying an "ERR 99" message.
To isolate the cause of the issue, we suggest that you do the
following:
Does the "ERR 99" message appear? If it does, then the camera should
steps:
Does the "ERR 99" message appear? If so, then the CF card is the most
camera body.
If the "ERR 99" message only appears when one particular lens is
If you see the "ERR 99" with a different Canon lens attached, then the
May 25, 2009 | Canon Cameras
Err 99 appears after every click for canon eos 30 D
Err 99, but lens-to-body problems are common- thought error 99 is a bit of a catch all- generally a lens and body conflict. And also Err 99 means that something wrong happened, but then it cleared out before it could be further determined.
Here is the blurb from canon to try:
following:
steps:
camera body.
For factory service, forward your digital camera (remove the CF card
and battery) properly packaged and insured, with a letter describing the
difficulties. Be sure to include your name, address, telephone number,
and proof of warranty (if applicable). Send to the Canon Factory
Service Center at the following address:
Canon Factory Service Center
100 Jamesburg Road
Jamesburg, NJ 08831
Tel.# (732)521-7007
or
15955 Alton Parkway
Irvine, CA 92618
Tel.# (949) 753-4200
Your equipment will be examined and you will be advised of the
findings.
The length of time for the repair will be dependent upon the nature of
the repair and availability of parts if needed. If the repair entails
something that is not covered in warranty you will be sent a written
estimate to the address that you have provided.
Please leave for me, a rating...
May 15, 2009 | Canon MF8180C Color Laser MFC Printer
ERR 99
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
To isolate the cause of the issue, do the following: -
4. Insert only a fully charged battery, and turn on the camera.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Apr 11, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Err 99 in canon 350D
Apr 06, 2009 | Canon Rebel XT / EOS 350D Digital Camera
''err 99'' code appearing fairly often recently on Canon Rebel XT
Does the “ERR 99′ message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99′ message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera is faulty and should be serviced.
Mar 19, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
128 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Ekse
Poul Brinchs Larsen
Are you a Canon Camera Expert? Answer questions, earn points and help others
