Indicator appears blinking lights on the printer " P,O, 8′. That Mean The print head temperature above the specified value. You can replace the ink cartridge or refill the cartridge. Step to resolv this error Step 1 : Turn Off Printer Step 2 : Remove Cartridge Step 3 : Refilling the cartridge Step 4 : Reinstall the cartridge Step 5 : Turn The printer ON If it still does not work you can use the following methods How To Reset MP 258 error 5200 Step 1 : The printer is off and plug the power cord. Step 2 : Press the button STOP / RESET and hold, then press and hold the POWER button Step 3 : POWER button still press, release the STOP / RESET, then press the STOP / RESET 2 times in a state of the power button is pressed. Step 4 : Release both buttons simultaneously Step 5 : The printer will proceed in a while (a while), then the LCD panel will show the number zero (0) Step 6 : Computer will detect NEW DEVICE, Ignore it... Step 7 : Press the power button, then the printer will turn off Step 8 : Press the power button again, then the printer will be ready to use
P03
Waste ink full reset
These are the instructions which worked for me on my Canon pixma mp470:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
