Ok well my blackberry curve 8520 was lightly tapped on a desk now the screen is all frigged up u can see anything and there is lines of colours nd i tried taking the battery out and back in but nothing worked nd i dont know how to fix it nd i really dont wanna lose any information i have or stuff i have on my phone by replacing it but i dont no what to do
Ok there are some things you need to do.
1 you need the disc that came with your 8520 This disc help you load desk top software. 2 You will need to backup your phone. You can still use this older software.It was make for the older blackberry. Now is your phone for personal or business. If you can backup all your important information on a 8-16 gb micro scan memory card. The more gbs on the memory card the more room you will have.If you need help ican walk you through the process on your computer. The curve is an older blackberry. It can be a memory problem. I suggest you get a bigger memory card and put it into your phone.
Hi, You can get the unlock code for a Blackberry Curve 8520 from http://www.unlocking4u.com/blackberry-8520-curve/rs6wp9/ at affordable cost. Here are the steps for unlocking a BB Curve 8520, 1 - Switch on your Blackberry 8520 Curve with any Sim card and Turn off all Wireless connections. 2 - Go to Settings. 3 - Go to Options. 4 - Select Advanced Options. 5 - Select SIM Card. 6 - Type MEPD using your Blackberry 8520 Curve keyboard (NOTE: You will not see any text appear on the screen while typing MEPD), 7 - Type MEP then hold 'ALT" key and type number 2.(NOTE: You will not see any text appear on the screen while typing MEP2), 8 - You will then be presented with a prompt "Enter Network MEP Code". Type in the Unlock Code and press in the track wheel / jog dial to confirm, 9 - Your Blackberry 8520 Curve will now be unlocked.
hi emily_ashdow go to blackberry dot.com and download the desk top manager on to your computer. The blackberry desktop manager can fix your problem. it will allow you to turn your radio connections
Sounds like your screen is physically broken. If your Somebody needs to open
your Blackberry and replace it. If you want somebody else to do
it for you go to Blackberry Repair. If you want to do it yourself, here is an Blackberry 8520 Repair Guide that shows how to repair a Blackberry.
just re install the blackberry operatind system software into ur fon from ur computer................and go on ....................or u can take off the battery and put it into again and press the return key when the red light goes off and till ur cell completly opens dont leave the return key..............it opens ur cell in safemode and u can deal with the error in safe mode
Sounds like you have a broken LCD screen. Somebody needs to open your
blackberry to replace it. Go to your provider, they might replace the phone
for you. If they refuse and If you want somebody else to do
it for you go to Blackberry Repair. If you want to do it yourself, here is a Blackberry 8520 Repair Guide that shows how. Try to look for the Blackberry Javelin repair guide, it is very similar.
I have the same problem, but it's a vertical white line. I have a BB Curve 8310. From what I've researched on the web, it seems the LCD screen wud have to be replaced.
sorry that was supposed to u can see anything
