LG X-Note LM50 Notebook Logo
Posted on Nov 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
MY LG e500 shows "Wireless
Anonymous
Level 3:
Genius:
  • Master 1,542 Answers
  • Posted on Nov 16, 2010
Anonymous
Master
Level 3:
Genius:
Answers
1542
Questions
5
Helped
287082
Points
4659
Hi
I would go to device manager go to network devices find the wireless adapter and uninstall it then restart your notebook and hopefully windows will reinstall it correctly then go into the properties and tell it to show in taskbar when available
9helpful
5answers
My whatsapp is showing "Error , status unavailable
its an app server problem, whatsapp confirmed on having it done!!
Nov 28, 2012 • iPhone Apps
Wireless router
Is this a laptop? if it is, see if there are any switches or buttons on the case. Most laptops have hard switches or buttons to turn off the wireless adapter, but Windows will still show it as enabled when you try to connect. Try to look for a button with an antenna or satellite symbol on or beside it. Just press it once, and then try to connect again. Try pressing the "refresh wireless networks" button in the place where you would connect to wireless networks. Hope this solves your problem :)
Wireless vgn-n130g i did wireless but it doent working can you help me how i take other software installer for wireless sony Thank you !
check is wi-fi driver install in device manager->network controller->network card names if it install close that on the right hand side there is a icon of network connection click on wireless ->refresh avil. network-> it show some connection select one of them u like click on connect button enter yr passkey you are now connected to your wifi if there are no network show that mean there some other problem rate my tips thank u
2helpful
Dell Inspiron 8600 Wireless connection driver Problem
I would check network connections in your control panel first and make sure your wireless connection is enabled. Next I would go to System in control panel and then go to device manager and check to see if the drive for the wireless is installed. May want to try here for the Driver download.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=08&l=en&s=bsdr&ServiceTag=29PS3G1&SystemID=Latitude%20D630&os=WW1&osl=en&catid=&impid=
Does LG E500 Have built in wi-fi? if so how do I activate it. trying to set up ADSL
Yes it has Wi-Fi. go to control panel/ network connections right click your wireless connection and view available wireless network
LG e500 won't boot up, black screen!!
I think this is a bios problem. Locate the bios lithium cell and replace it and try again
2helpful
Can the Compaq Armada E500 go wireless?
hi,
any laptop has the capability to use wireless connection, if you connect to that laptop a compatible wireless card and install its drivers( the cd/dvd that comes with the wireless card)
to check if this card is ok or not try using it on some other laptop see if it works there and gets the networks
further Queries are welcome
Problem with wireless internet connection
is your wireless card installed check in the installed devices section and see under network controllers if there is a wireless if not you'll need to run windows update via a lan and get the drivers if not find the support page for your laptop and download the drivers for the Wireless LAN card.
Dlink not working on my computer that receives signal
visible & unavailable means that the wireless security settings are not the same on the recently formatted computer, as on the rest of the network.
Open the wireless configuration for any computer that can connect to the network and copy the security settings (wep or higher) to the unconnecting pc
OR
connect to the router by cable from the non-connecting pc, use the web interface at http://192.168.0.1 to read the security settings, and copy the settings to the unconnecting pc
then it will connect
2answers
Problem with wireless connectivity for LG-E500
u try to reset roughter unplug it back in after 20 sec do u have latest driver for your wifi in from lg or windows update custum scan im open for chat
Top LG Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
