Hi
you don't happen to a service manual for hp officejet 7110 laying around do you I just got this great deal at the thrift store $16.00 the printer and fax work and the light on the scanner works but it is stuck I hear it clunking so i know it is trying to move I have it about ready to remove the glass but now if i only new for sure what i was suppose to do exactly i could save myself time from my standard learn as you go routine
Hp officejet 7110 caterige chip rest code
In this case i dont think you need to service manual.. Preety much you got the basic concept down ITS STUCK.. remove the glass as you are thinking,, and look at the gears and wheels see if any is broken or slipped,, if there is a band enusre its in place.. If everythiing is ok. then move the scanner inamger (THE THING THAT MOVES WHEN U SCAN WITH THE BRIGHT LIGHT) all the way down then back up then back down again.. this will loosen it up.. now mount it and plug it in ,, this should solve your problem..
concerning the service manual i dont have one for that model but if you goole
officejet 7110 service manual free
i'm sure you can easly find one with a little poking around
