SOURCE: How to tighten the hinges on a slow close toilet seat?
You don't want to overtighten since you could crack the porcelain. Are your rubber washers in good shape? This will help. You should be able to do this w/out doing any damage.
SOURCE: Removing rusted nuts from bolts to replace toilet seat
Try:
* Penetrating oil...let it soak at least 1/2 hour
* If the nut is stripped, try either grabbing it with vice grips
* If all else fails, either grind it off, or use a nut splitter. Nylon is pretty soft, so it should be relatively easy to break
SOURCE: We have 3 soft closing Toilet seats.Newly
Reach under the bowl of the toilet and feel for a rather large wing-nut bolt on each side of the toilet. You must hold these with your hand and tighten the screws with a screwdriver. If you don't hold these wingnuts, then the screws will keep spinning forever and never tighten. Run your hand directly below the toilet just below the screws and you will find them. VERY EASY FIX!
SOURCE: loose Toto toilet seat
Lift up plastic caps located on ends of hindge behind seat. use flat screw driver and hold the nut under the outside toilet rim with your fingers or a pair of pliers. Do not over tighten or might crack the bowl.
SOURCE: toilet seat come loose and no obvious way to
well there should be 2 hinges rite behind seat. you wont see the screws cause they are under a plastic cover. take a flat head screw driver and pry up cover. lil cover should lift up towards tank. then you should see screws. the nut is under bowl you have to bend down then look up to see them or do what i do and feel for them. take big flat head or big philips screw driver and while you hold nut titen screw. hope this helps. duane:)
