SOURCE: Jenn-Air dishwasher jdb1100aws problem
I had the same problem , needed a seal kit w/ alignment tool.
repair part # 99003341.
SOURCE: Dishwasher Heating element not working
my wife shut the water off to the dishwasher and forgot to turn it back on and then used the dishwasher.
the heating element went on but there was nop water.
when we turned the water back on,the drying cycle does not work.i would think that the element needs to be changed or is there a relay on the computer board?
this is a two year old Jennair unit.
any suggestions?
SOURCE: plastic melted on Dishwasher heating element
youll have to run a whole cycle again and pay attention to when the heating element comes on again. Once its hot the plastic will be soft enough to remove it with a tight cotton rag. Use you oven mitts for protection. Hope this helps
SOURCE: Frigidaire hot water problem
no, i don't think so. the heating element is located under the inside tub and out of the dish area. if you could supply me with the make and model #, I will try and find the exploded view for you. the element is replaceable.
Check
your heating element..
A
bad heating element causes many problems in dishwashers...
Dishwasher
Problems The Heating
Element not Working
How
to Replace the Dishwasher Heating Element
Dishwasher
Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give
it a go and see how simple it was. thanks Ronnie " -
ronnieshomes
