Question about Belkin (F5D72304F5D7000) Router
I need my network security key? - Belkin (F5D72304F5D7000) Router
Is there an easy way to secure
Welcome to Fixya. If you want to set a password of the network to make it secure you need to access the router page.
To access the router page you need a working computer that is connected to the router. To access your router you need to use a computer that is connected to it. Open a Browser then type 192.168.0.1 or http://routerlogin.net. The Default username is admin and the password is password. Password is case sensitive.
Go to the Wireless Tab select Wireless Security select either Wep, Wpa or WPA2 under the Security Mode you will see there Network Key (Wep/Wpa Key) or Passphrase. The Network Key serves as a password or security code on your network to make it secure. Network Key is case sensitive.
Thanks for using Fixya
Apr 19, 2011 | NetGear WGR614 Wireless Router
Trying to secure wireless network
Welcome to Fixya. If you want to secure the network you all you need to do is to access the router settings page and put a security either WEP, WPA or WPA2 and a Network Key or Passphrase.
To access the router page you need a working computer that is connected to the router. To access the router page just open a browser then type 192.168.2.1, the Default password is blank
Click on Security under Wireless, Select WEP, WPA or WPA2 and personalize a Security Key or Network Key (Passphrase). Security Key serves as a password on the network.
If you have questions please let me know. Thanks for using Fixya.
Mar 25, 2011 | Belkin (F5D7633UK4A) Wireless Router
I have WII and Linksys. Can not connect it to internet. Yes, I know my wireless password key.
Welcome to Fixya. If you need the Network Key you need to access the Wireless Settings Page.
To access the router page just open a browser then type 192.168.1.1, the Default username is blank and the password is admin. Go to the Wireless Tab select Wireless Security under the Security Mode you will see there Network Key. The Network Key or Wep Key serves as a password or security code on your network to make it secure.
Mar 13, 2011 | Linksys Wireless-G WRT54G Router
How do I find my security key #?
Welcome to Fixya. If you need the Security key or Network Key you need to access the Wireless Settings Page.
To access the router page just open a browser then type 192.168.1.1, the Default username is blank and the password is admin. Go to the Wireless Tab select Wireless Security under the Security Mode you will see there Network Key or Security Key. The Network Key serves as a password or security code on your network to make it secure
Mar 11, 2011 | Linksys WRT160N Wireless Router
How do I find my WEP Key?
You can give a try using the HP Network diagnostic tool and it should give you your network details
Click on the link below and follow the steps
HP Network Diagnostic Tool
Regards,
Ron
Feb 25, 2011 | Linksys Wireless-G Broadband Router
Need to accessmy router wep code
Hi wdarrel11,
Welcome to Fixya. If you need the WEP key or Network Key you need to access the Wireless Settings Page. To access the router page just open a browser then type 192.168.1.1, the Default username is blank and the password is admin. Go to the Wireless Tab select Wireless Security under the Security Mode you will see there Network Key or Wep Key. The Network Key or Wep Key serves as a password or security code on your network to make it secure.
If this works dont forget to say thanks. Thanks for using Fixya.
Feb 06, 2011 | Linksys Wireless-G Broadband Router
The router is blocking access to one computer asking for a network security key which is apparently different from the password. How do you find the security key?
Hi camavery,
If you want to the security key you need to access the Wireless Settings Page. To access the router page you need a working computer that is connected to the router. To access the router page just open a browser then type 192.168.1.1, the Default username is blank and the password is admin. Go to the Wireless Tab select Wireless Security and under Security Mode you can see the Network Key or Passphrase. The Network Key serves as a password on your network to make it secure. You can personalize the Network Key so that you can easily remember it. Then Save the settings.
Feb 05, 2011 | Linksys WRT54GX2 Wireless-G Broadband...
Need security key
In case of 2 wire router the security key is on the back side of the router.
if you turn it upside down you will find 10 digit number. That might be your security key for the wireless network.
if network key is not there or it is not working then you will need to open the setup page of the router and find out the network key.
if you have any computer connected to the router then use that computer to find out the network key.
Click Here for more information about the routers and network
Oct 25, 2010 | 2wire HomePortal 1000 Router
What does it mean by network security key
The name 'network security key' is itself self-explanatory. Every network has a security key and you will need this key to be a part of that network. Just as is the case of any other term that comes from the field of network engineering, there are a lot more details attached to this term, too. So, let us try to understand all the aspects related to network security key
An explanation as to why we need a wireless network security key is not even required. Still, if any one is skeptical about adding any complexity to their available wireless network, just think about it. Your wireless network range can be detected by any other computer with a wireless setup and that comes within the range of the network. So, without you knowing, it's very easy for any user to get connected to your wireless network and gain access to all the data that you intend to share only with those computers with which you have setup your wireless network. So, what is a wireless network security key and how is it useful in such situations?
Well, a network security key or passphrase is something like a password, which any user who wants to connect to your computer will require. But, I think that before we go into the details of figuring out, how to get network security key for wireless computer, we should take a look at the different methods of securing your wireless network
Oct 03, 2010 | Computers & Internet
What is the WEP key
Wired Equivalent Privacy (WEP)
WEP is an older network security method that's still available to support older devices, but it's no longer recommended. When you enable WEP, you set up a network security key. This key encrypts the information that one computer sends to another computer across your network. However, WEP security is relatively easy to crack. f4008eb.jpg
Nov 16, 2009 | NetGear WGR614 Wireless Router
Belkin (F5D72304F5D7000) Router Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Ekse
Jeffrey Groves
Jeffrey Groves
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
