The control board has relays on it that are not user replaceable unless you can solder. You also must be able to find them since they are integral to the control board. I have attached the board info to this post. I would change the door switch before I changed the control board. http://www.appliancepartspros.com/lg-main-electronic-control-ebr34917104-ap4450216.html
SOURCE: LG Refrigerator LFX25960ST Dispenser Panel
Here are four ways to reattach the panel:
- Put a short stainless steel screw in each of the two lower corners of the panel. Drill a hole in the panel first -- the hole should be bigger than the diameter of the screw. Next, with the panel in place, carefully drill thru these holes, into the door, a hole smaller than the diameter of the screw. Then screw the panel back on.
- Or, put thick double stick tape along the bottom of the opening for the panel. Two short pieces would be preferable -- this would make it easier to remove.
- Or, if there is enough PVC in the plastic panel, PVC pipe solvent may allow you to refasten the broken clips to the panel. (This is available at hardware stores -- you may want to use PVC primer as well -- but be very careful, the primer is purple, very "thin", and will run -- it will stain everything it touches. If the panel is not PVC, this solution will not work.
- Or, 5-minute epoxy may hold the broken clips to the panel (make sure the epoxy is thouroughly mixed).
SOURCE: Water is dispensing very slowly and I just
yup,
i would turn your freezer down a few degrees, you are more than likely expeiancing, whats called migration frost, cold air from the freezer, could be freezing your water resivoir or the line from it
causing bad pressure
SOURCE: Replace stainless steel cover of refrigerator door
Warner's Stellian in Saint Paul, MN can replace for you. For cleaning we reccommend DeBruce Polish.
DeBruce Polish is Odorless, Non-Toxic and non abrasive and perfect on
stainless steel, glass cook tops, polished granite marble and more.
DeBruce Polish is Odorless, Non-Toxic and Non Abrasive. DeBruce is
perfect on
We buy DeBruce at debrucepolish.com.
SOURCE: Mother Board
Laura,
You win. Most GE side by side refrigerators have an electronic mother board.
Data is feed to it from 5 thermistors, 2 in the freezer and 3 in the fresh food compartment.
In turn the motherboard takes that varying information from the thermistors and controls all functions in the machine.
Testimonial: "Thank you!!!!"
SOURCE: my LG refrigerator model #
my refrigerator before making a loud noise when we open the door. i called mr.apliance he replace the evaporator fan.......
