Dell 922 All-In-One InkJet Printer Logo
Posted on Nov 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I want to refill my Dell a920 catridge so how much ink i can put in one portion ????
Anonymous
Level 3:
  • Master 428 Answers
  • Posted on Nov 14, 2010
Anonymous
Master
Level 3:
Answers
428
Questions
0
Helped
108358
Points
1406
Its usually better not fill up your cartridges completely ti the brim. About 3 - 4 ml at a time should do. Or observe the body of the cartridge for any volume indicated on it. If it is 4ml you may put in about 3 ml etc.
Good luck & God bless!
2answers
I keep getting a error code 1203 what does that mean
Hello
It means your catridges overflow even from brand new catridges after several prints or right after you refilled the catridges. Check to see if ink are smeared on the holder where the contact panel with the catridge
use a klennex with a few drops of water to dampen and clean off those contact on the holder and your printer should work again.
The refill ink work very well if you let it sit 24 hrs. Then before you print anything, you should run aligned catridges a couple times then run clean catridges a couple times.
Print the test page to see how it looks .
Be sure not to leave any debris of klennex on those holder contact panel.
1helpful
How do I clear an error code 1203 on a DELL 926 printer?
It's mean your catridges overflow even from brand new catridges after a several prints or right after you refilled the catridges. Check to see if ink are smeared on the holder where the contact panel with the catridge. I have the same problem which I think lexmark have a proble and overlook.
Solution:
I use the klennex with a few drops of water to dampen and clean off those contact on the holder and my printer work again.
The refill ink work very well if you let it sit 24 hrs. Then before you print anything, you should run aligned the catridges a couple times then run clean catridges a couple times.
Print the test page to see how it's look and way you go.
2helpful
I can't get the red to print and supposedly their is red ink in the cartridge
make sure all the catridges are proper if possible then replce it and re install the printer driver also.
Canon mp460 printer. refilled cartridge not recognised
Dear Sir,
This is deffinately due to catridge circuit problem.Canon suggest that we have to replace emptied catridges with new genuine canon catridge they dont suggest refilling and also not give any support for refilling catridges. So you can replace catridge with new one.
This Happens due to weakining of catridge circuit portion or may long period printer not in use.
If you not want to replace catridges i will give you the possible hints it may fix refilled catridges.
1.Clean the catridge circuit portion with soft cloth,care must be taken that there is no smudge or ink traces on catridge circuit.
2.Clean the ciruit of printer catridge placing box present inside the printer .wipe out the any sumdge or ink traces.
Then re install the catridges. give the print if it shows error press resume button continuosly. I think it will fix your problem.
If it is not solution is replace the catridge with new one.
good luck
Error 1203.
Solution:
Dell Series 5 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges.
Dell Series 5 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
regards
iversh
A very helpful rating is appreciated for answering your query...
2helpful
Ran ink out of resevoir tank how do I refill
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download dell printer software from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
1helpful
DELL PRINTER A920 PRINTING IS BLOGGIE
Hi! Your problem is your printers INK CARTRIDGE alignment, make sure that your printer ink cartridge is properly aligned. Or try to clean your ink catridge. GOOD LUCK. THANKS
KEEPS SHOWING LOW INK/
you get from dell 922 all in one software 'replace catridge' option use that option
I've installed a new coloured catridge but printer
did u remove the peel off cover that protects the contacts or the print head on the new cartridge?
How do i refill a ink cartridge for a dell 720 printer
don't refill yourself just take the catridge to any of the computer repair shop just ask them to refill or else buy a new catridge of the same type
Top Dell Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Ngoro
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
