Hi-
When you said line feed do you mean the Top of form?
hope this helps
1. Make sure the printer is turned on and the desired tractor is selected (the corresponding tractor arrow should be lit).
2. Open the upper cover.
3. Press the Top of Form button to enter top-of-form mode. The printer beeps once, and the Top of Form light turns on.
4. Use the Micro Feed buttons to feed the paper to the desired top-of-form position. The “A” on the ribbon protector shows you where the bottom edge of your first line of text will print. This position is based on the first printable line of text. If your software inserts a top margin of five lines, your text will actually print five lines below the top-of-form position.
5. Press the Top of Form button again to exit and save your new top-of-form position. Then close the top cover.
Keep me posted if you have inquiries, thanks!
Setting Top of Form, Forms Tear-Off ON
(Step A)
! If you turn the platen knob when the printer is turned
on, you will cause the Top of Form to mis-align. Always
turn the printer off before turning the platen knob!
1 Turn the printer ON.
2 Park the paper.
3 With paper out of the unit, (red alarm light should be on)
press SHIFT (1) and QUIET/TOF (5) to reset the current
Top of Form.
4 Press FF/LOAD (3) to load the paper.
5 Press SEL/MENU (6) to take the printer off line.
The SEL light goes out.
6 Wait until the paper moves up to the tear position, then
press and hold TEAR (4).
The paper moves to the current Top of Form.
Keep pressing and holding TEAR.
7 Press and hold SHIFT and release TEAR.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
