Just fried our Sanyo EM-710F microwave circuit board. Urghh After 16 years service first the Magnetron and fuse diode across the HV cap went last week. Replaced them and all working OK for 1 day. Then while door open to clean a spill, a big bang and unit dead & no display. Found fuse and interior light blown- replaced and display still dead. Checked high voltage circuit and all seems OK (but this would not influence the dead display). Removed display circuit board and found track from circuit board connector 'S1' pin 5 to Tx vapourised. Primary winding of Tx measures open circuit too (measured across the Tx primary itself). Have not yet desoldered Tx to see if any hidden fuse link or damage there. Also some heat damage around components R12, R18, D14 (but these resistors still measure correct resistance). Urgh. hope there is a fuse link or something under Tx. Not sure where to get this part if stuffed? Tx is marked 'PE5M-257. Any suggestions on Tx source?? Any suggestions if anything else is likely stuffed too? Many thanks if you can help. Cheers, john
A diode is an electronic component that
readily passes current in one direction only and blocks the flow of
current in the opposing direction. If your microwave's diode has become
defective, your microwave will not heat and you will hear a buzzing
noise. Test the diode to determine if this is the cause of your problem.
Replace it if it is defective.
A capacitor is an electrical device
which stores electricity. A defective capacitor may be why your
microwave is not heating but you are hearing a buzzing or humming noise.
The capacitor will have to be tested to determine if this is the cause
of your problem. A defective capacitor will have to be replaced before
your microwave will work again. Make sure you discharge the capacitor before you test it, though.
A defective magnetron is the third
possible cause of why your microwave is not heating, but you can hear a
buzzing noise. Test your microwave's magnetron. Replace it if it is
defective.
It sounds like the magnetron may have
either failed or is not being supplied with the extremely high
voltage required to run it.
YOUR
SAFETY IS PARAMOUNT
This is a job for a professional but if
you are safety clued up, here's instruction.
Make sure the !!!!any
capacitors are discharged!!!!! before attempting any sort of
repair.
Check the door interlock switches first then the high
voltage diode with either an AVO model 8 or moving coil meter on high
resistance range for short circuit, (DVM's won't show the fault!),
the capacitor can fail and go short circuit, the feed fuse on the
primary of the high voltage transformer and then finally, the
magnetron is best checked by substitution.
Hope that helps.
YOUR
SAFETY IS PARAMOUNT
repair.
Hope that helps.
The magnetron may have either failed or
is not being supplied with the extremely high voltage required to run
it.
The cooling fan and turntable motor get their supply from the same point as the main transformer. If the magnetron or diode has failed that will cause excess current to be drawn and take out the supply fuse.
Make sure the !!!!capacitor is discharged!!!!!
before attempting any sort of repair.
switches first then the high voltage diode with either an AVO model 8
on high resistance range for short circuit, the feed fuse on the
Hope that helps.
