SOURCE: ip config is not finding my ip address?
No IP address? most likely the network is diable or the network card drive is deleted.
right click on the network icon>>porperties. if you see a network icon then right click on it and enable the network, if not, then the network driver is deleted.
go to control panel>>system>>hardware device, and see if there is a (red X) on the nework card.
go to the vendors website and download the network driver.
good to go!!!!!!!!
SOURCE: my emachine T3624 i bought used, and i cant get norton off of it,
Hi and welcome to FixYa,
Norton has a habit of being so good that it interferes with some normal activities. Should you wish to uninstall a Norton product and if at all possible, download and run the Norton Removal Tool. Soon as the Norton Product is un-installed, remove the remaining Symantec folders in Common Shared folders. Thereafter, pls follow below procedures:
Below listed are the default program folder names and locations listed by program:
It would help to configure Windows to show all files.
Having performed the above, search for and delete all Symantec folders.
and delete all the 3 folders.
Finish by cleaning up the Registry:
CAUTION: you must back up the registry before you make any changes to it. Incorrect changes to the registry can result in permanent data loss or corrupted files. Modify only the keys that are specified.
HKEY_LOCAL_MACHINESOFTWARESymantec
HKEY_CURRENT_USERSoftwareSymantec
Pls post back results. Good luck and thank you for using FixYa.
SOURCE: T6524 bios update needed
This isnt necessarily a bios problem mate , its just windows got corrupted during the power surge. Use the link below to do a repair install. Note , repair installs do not erase your personal files or setings or software !
http://michaelstevenstech.com/XPrepairinstall.htm#RI
Hope this helps you
If you found this solution helpful , please rate below
Kind Regards
1234s282
SOURCE: I dont have ethernet drivers.
cambie mi emachines de vista a xp es 1161-05 y no me puedo conectar ainternet
SOURCE: Emachine won't connect to the internet. Ethernet
first try to check if your wireless can actually detect a network, if it can try to remove ALLthe network that you have on your wireless network and try to add your network again, if still doest work try to uninstall and re install your wireless driver, if it still doesnt work try to restart your router, if still doesnt work try to do system restore to the point where your wireless was workin fine, lastly if still doesnt work try to contact your ISP for some configuration.
