Canon PIXMA MX300 All-in-One Printer Logo
Posted on Nov 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Scanner will only scan 2 items then quits. or will not scan at all
Level 3:
  • Canon Master 7,733 Answers
  • Posted on Nov 12, 2010
Canon Master
Level 3:
Answers
7733
Questions
0
Helped
1864835
Points
21487
I've got a all-in-one printer of HP LaserJet M1120 MFP. When I switch it on the screen shows "Scanner Error 20". And I cannot use the scan function. It can print when connected to computer. I've rea
Follow these steps to scan using HP software:Step one: Load the item to be scanned
  1. Make sure that the product is connected to the computer.
  2. Turn on the product.
  3. Load the item in the document feeder tray or on the scanner glass
Tip
Load the following items in the document feeder tray :
  • Single items
  • Items that are not easily damaged
  • Multipage, single sided items that you want to scan into one file
Load the following items on the scanner glass :
  • Single items
  • Items that are easily damaged, such as old documents and photos
  • Multipage, double sided items that you want to scan into one file
  • Option one: Document feeder tray
    1. Place the item into the document feeder tray. The printed side faces up and the top edge goes into the tray first.
    2. Adjust the width guides to fit the item.
  • Option two: Scanner glass
    1. Open the scanner lid.
    2. Place the item with the print side down on the scanner glass. For the correct position, see the engraved guide near the corner of the glass.
    3. Close the scanner lid.
Step two: Scan the item Use one of the following methods to open the HP scan window:
  • Double-click the HP scan icon (c02436443.gif ) on the Windows desktop. note.png NOTE:If you have more than one HP product installed, double-click the HP scan icon (c02436443.gif ) for the product you are scanning with.
  • Click Start (c01827528.gif ), click All Programs , click the HP folder, click the name of your HP product, and then click HP Scan .
Click the scan option for the item you are scanning. note.png NOTE:Depending on your HP product, you might not have all the following scan options available. c02448891.gif
Save as PDF Use this setting to scan text documents that are not editable. Use the Save as Editable Text (OCR) option to scan text that you can edit. c02448892.gif
Save as JPEG Use this setting to scan pictures and images.
Hope this information will be helpful.
Let me know.
Regard
10helpful
How do you use the scanner on the Lexmark 4690 3-in-one? I have never used the scanner on my printer. How do you do it?
1 Open the top cover 2 Place the original document or item face down on the scanner glass in the lower right corner 2 Close the top cover to avoid dark edges on the scanned image.
3 From the printer control panel, press .scanned
2helpful
Hello, I am attempting to scan an important document and the printer keeps saying "set the document on the platen glass" the document is there but it keeps saying the message
The best way to scan images to save on yourcomputer is to use the scanner software on the computer. Not the scan functionon the scanner.
You don't say what type of scanner software you have but usually scannersoftware works this way:
1) Place photo on scanner
2) Open scanner software
3) Using the software, Initiate scan
4) Name the Scanned item and save it to your desired location/folder
Note: some applications will automatically save to --My Documents--My Pictures
5) Repeat process for each pic to be scanned
1helpful
I have a barcode scanner Symbol S/N M1J82M51E. When scanning the item barcode it makes very low volume. How to increase the bipping scanning volume for the Symbol Scanner?
1. Press and hold the trigger for an extended period of time (approximately 5 seconds). The scanner cycles through three settings (Low, Medium, High) emitting a 2-beep tone at each setting.
2. To select a particular setting, release the trigger after you hear the desired 2-beep tone.
I am trying to scan a document and it is not working, I have a hp photosmart c4280 printer. How do I install a usb cord
hi
Place the document or image into the scanner for scanning. A scanner with a paper feeder will only receive flat papers and photographs, but a flatbed scanner opens to accommodate books, fabrics and leaves along with flat papers. There is even a attachment for feeding photo slides into flatbed scanners.
  • Step 2 Start the scanning softwaremag-glass_10x10.gif. If the scanner does not engage the software automatically, press the "start" or "scan" button, or click the scanner icon on the computer screen to initialize the software.
  • Step 3 Activate the scan. Click the "file" menu and select "acquire," "import," or another practical choice that applies.
  • Step 4 Preview the item to be scanned. Most scanners have a preview option. This will show the scan area inside dotted lines. The lines can be moved with the mouse to relocate, enlarge or crop the scanning area.
  • Step 5 Set the resolution for images by number of dots per inch (dpi). For computer screen viewing, 100 dpi should suffice. Use 200 to 300 dpi for items to be printed.
  • Step 6 Use the appropriate setting for scanning black and white text. If the scanner does not show a preset for text, use "line art" or "black and white" at 300 dpi. Then use the optical character recognition (OCR) program to convert the image of the text into a file for word processi
  • 2helpful
    Canon scanner speed slow
    Various ways....Try these! the slow problem wil get off
    How to change the resolution (Windows)
    The precision of printouts can be improved by changing scanning resolution.
    The higher the scanning resolution is, the more precise the scanned images are represented, however, the file size gets larger.
    The scanning resolution can be changed before scanning photos.
    Note: When the scanning resolution is doubled, the image data size will be quadrupled.
    When the data size is large, the throughput speed may slow down or may occupy too much of the computer's resources (memory).
    <Procedures>
    Memo: The following is explained using MP Navigator 3.0 procedures.
    To scan using MP Navigator:
    1. Launch MP Navigator and click Photos/Documents (Platen) on the Scan/Import tab.
    80006642en_05sj00759_en_00.jpg- The window you see varies according to the printer model.
    2. When the Photos/Documents (Platen) window is displayed, click Specify.
    3. When the Scan Settings window is displayed, select the resolution in Scanning Resolution.
    If necessary, set other items as well.
    4. Click OK.
    5. In the Photos/Documents (Platen) window, click Scan to start scanning.
    6. Changing the resolution is completed.
    To scan using the scanner driver:
    1. Launch MP Navigator and click Open Scanner Driver on the Scan/Import tab.
    80006642en_05sj00765_en_01.jpg- The window you see varies according to the printer model.
    2. Change the resolution.
    According to your purpose, set the resolution in Simple Mode with ease, or in Advanced Mode with a detailed setting.
    - To set the resolution in Simple Mode:
    (1) Select the Simple Mode tab.
    (2) Select the output resolution from the Destination pulldown menu.
    If necessary, set other items.
    - To set the resolution in Advanced Mode:
    (1) Select the Advanced Mode tab.
    (2) In Output Resolution, select one of the preset resolution, or enter the number from 25 to 19200 to specify your favorite resolution.
    3. Click Scan to start scanning.
    4. Changing the resolution is completed.
    Scanning to import to a computer
    Normal 0 The best way to scan images to save on your computer is touse the scanner software on the computer. Not the scan function on the scanner.
    You don't say what type of scanner and software you have but usually scannersoftware works this way:
    5) Repeat process for each pic to be scanned.
    Not scanning
    You have tried everything possible!. Try and reinstall the OS. If some dll files are corrupted, this will resolve it. You may have to reinstall all other software!
    S. Mohan
    2answers
    NOT SCANNING CORRECTLY
    I'm guessing you are using the USB version and the power that comes from the comuter via the USB cable.
    It is quite likely that the problem you are having is due to power sag. .500ma is the limit from P.C. s
    Do you have a 15 foot cord on there? If so try a 6 foot cord. Sagging still occurs with a 6 foot cable ...but only half as much. If the problem goes away you are on the right track.
    I have a cable (I should say Motorola has a cable) with a separate power supply that should fix the problem.
    Microtek ScanMaker S400
    Check the scan with normal flat copy. If that scan is OK it is not the scanner.Have a rethink about how you are scanning If the the test scan comes up odd Come back with what software you are using to with thew scanner[Image editor etc.,] Do more tests before junking the scanner - that will be last move.
    old marine
    old marine
    ZJ Limited
    ZJ Limited
