3-Series (Except M3, M Roadster, M Coupe, 318ti & Z3)
1. Raise and support vehicle. Remove wheel(s).
2. Remove axle shaft. See appropriate AXLE SHAFTS article.
3. Remove brake disc. See BRAKE DISC .
4. Screw special tool (33 2 116) onto drive flange with wheel studs. Drive out drive flange with special tool (33 4 201/202/203). See Fig. 33.
5. If necessary, pull off bearing inner race using special tool (00 7 500) and a thrust piece. See Fig. 34.
6. It may be necessary to remove inner wheel bearing race with the following procedure:
7. Remove circlip. See Fig. 37 .
8. Remove wheel bearing with special tool 33 4 031/ 041/ 042/ 043/ 045. See Fig. 38 .
CAUTION: Do not reuse old wheel bearing.
9. Draw in new wheel bearing with special tool 33 4 041/ 042/ 043/ 047. For inner bearing race 42 mm use special tool 33 4 049 and for 39 mm use 33 4 046. See Fig. 39 .
10. Installation is reverse of removal.
11. Replace stretched or damaged circlip. Ensure correct seating.
12. Pull in drive flange using special tool 33 4 041/ 042/ 043/ 045/ 048. See Fig. 40 .
13. Install brake disc.
14. Install axle shaft.
SOURCE: BMW 325i noisy fan bearing Can I replace it.
yes easy you remove the fan and change the whole unit its not repairable
