Frigidaire FGFB75D Gas Kitchen Range Logo
Posted on Feb 28, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I wanted to clean the top of my Frigidaire Gallery gas stove, so I sprayed it with cleaner. I must have gotten the burners wet, because now the pilot light is out and the burners won't light up. The stovetop doesn't lift up and I need to know how to relight the pilot light. HELP!!!
Terry Weaver
Level 3:
Master:
  • Master 412 Answers
  • Posted on Feb 28, 2018
Terry Weaver
Master
Level 3:
Master:
Answers
412
Questions
Helped
119918
Points
1235
If it's a standing pilot (on all the time), rather than a spark igniter, just hold a match in front of the pilot orifice and it should light.
4 Related Answers
Anonymous
  • 150 Answers
  • Posted on Apr 22, 2008
SOURCE: frigdaire gallery stove
lock mechanism is acting up. happens sometimes. you can get to it from the back and get the thing open to use until you get the part
IFIXALL
Archie Ferrarini
  • 869 Answers
  • Posted on Jun 09, 2008
SOURCE: I have a Frigidaire Gallery
Have to check if there is power at the oven & broiler first.Maybe a bad thermostat located in back of oven wall.
Anonymous
  • 7 Answers
  • Posted on Jan 30, 2009
SOURCE: How to lite a pilot lite on a frigidaire "Gallery" gas stove?
wet sparkers, let them dry out good
David Burk
  • 49 Answers
  • Posted on Sep 09, 2009
SOURCE: Drexia clarifying previous post on gas range stovetop cleaning.
I have found that kitchen cleanser and a crub pad along with good old fashioned elbow grease is your best bet...
The fine scratches might come out with a good rubbing compound like the type used on car finishes...
While does my Elve stove top keep clicking ? I've cleaned the igniters. Turned off the power but they keep clicking
If you have cleaned the igniters on your Elve stove top and turned off the power, but they still keep clicking, there may be a few potential causes:
  1. Wetness or moisture: If any of the ignition switches, spark module, or wiring harness has gotten wet or damp, it can cause the clicking sound to continue. Try drying off the stove top and allowing it to sit for a few hours before trying again.
  2. Loose wiring: Check the wiring connections on the spark module and ignition switches to ensure they are tight and secure. Loose wiring can cause a short circuit and result in the clicking sound.
  3. Dirty burners: Even if the igniters are clean, the burners themselves may be dirty or clogged, preventing gas from flowing properly. This can cause the igniters to continue clicking in an attempt to ignite the gas. Try cleaning the burners thoroughly and see if that resolves the issue.
  4. Defective parts: If none of the above solutions work, there may be a problem with the spark module, ignition switches, or wiring harness. In this case, it may be best to contact a professional technician to diagnose and fix the issue.
Stove not working
You have a failed communication within the main control board. Please consult a professional or your manufacturer before going further.
2helpful
How do I raise the cooktop on my Frigidaire Gallery Model #GLGF377ASE . I need to access the burner orifices.
If you raise up the top you will break the tubing going to the burners. You must remove the screws on each sealed burner before raising the top. Look closely and you will see the screws. They will be hard as heck to come out. If a stove is real old and I cannot get the screws out I dremmel the screw heads out and drill out the screws. I do a repair and then pop rivet the burners back on. If I have to go back in there it is nothing to drill out a pop rivet. That is how I do it on real old stoves. You may figure out a better way. You have to get those burners loose or you will break those lines below the top.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
2answers
Want to clean under stovetop
Hello
welcome to Fixya,
This stove has sealed burners and there is no need to lift or clean under anything except the burner caps.
You can not get inside the top and you can not lift the top like the old pilot stoves!
When you clean the burners and around rings do not spray or saturate the are and or the igniter element that creates the spark.I'll be back in a moment with your user manual.
first what is the complete model number of your range as written on the sticker in the door jam of the storage compartment down below. left side!
Huuum
1helpful
Frigidaire Gallery Professional Series - No clock/oven functions
i have an old model of the fridgedare gallery professional series stove. After self cleaning, the ignition sparks for the burners will not come off, they keep clicking and only stops when i pull out the plug. can you help me with this situation?
Gas range
I have a frigeidaire classic gas range 12 years old worked fine until a pot of water leaked over the stove top burners. now the door locked lite is on and the door lock is activated , the oven door is open and won't close. The oven also does not work now, although the stove top burners work fine.
Can you help ? Thanks, Tom
Top Frigidaire Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
