Toshiba Satellite Pro 4600 Notebook Logo
Posted on Nov 12, 2010
I have a toshiba satellite pro 4600 - no power at the display or lights - the power supply is working?
Anonymous
Level 1:
  • Contributor 942 Answers
  • Posted on Nov 12, 2010
Anonymous
Contributor
Level 1:
Answers
942
Questions
0
Helped
209464
Points
57
Yes youre right, the power supply or the motherboard is not working. You can try to press and hold the power button for 8 secs to turn it on. If it is still did not work, call toshiba for possible power supply or motherboard laptop repair...
1helpful
2answers
Hello, is there any difference between various Toshiba Satellite Pro 4600 motherboards? Would it be hazardous to buy one of those old models to replace another (unfortunately dead) Mb? (got a PIII750...
They are the same.
The Toshiba Satellite Pro 4600 is a model series.
Hazardous? In what way? Solder joints containing lead?
I don't have an exact Service Manual to give to you. But if you look through these, you should be able to find enough information to disassemble your laptop.
1) http://www.irisvista.com/
2) http://www.irisvista.com/tech/
[I found this in a search just now. Wanted to see if it used a mobile Processor or Desktop Processor.
{Uses mobile}
http://www.pchub.com/uph/model/0--2424-1/Satellite-Pro-4600-parts.html
Page 3 shows the motherboard ]
Why is my toshiba satellite pro 4600 keyboard not work?
There is not so much that could be done to repair a keyboard. Disassemble the laptop, check the ribbon cable connecting the keyboard to the motherboard. If the ribbon cable is loose, tighten it. If it is tight, replace the keyboard with a new one
2answers
Is it easy to install memory on my toshiba satellite pro 4600
Memory Upgrade for Toshiba Satellite Pro 4600 800 Laptop, the Toshiba Satellite Pro 4600 800 Laptop takes the PC100 SDRAM SODIMMs. 256MB module must be 1" in height or less Memory Type, and comes installed with 128 MB (removable) of Memory. You can upgrade your Toshiba Satellite Pro 4600 800 Laptop to up to a maximum of 512 MB Memory, the system has 2 sockets to install Memory, already with 128 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
You can obtain your models service manual with instructions for how to replace and upgrade memory from this link. http://www.givemefile.net/smanuals/notebooks/toshiba/file/31033.html
Hope this helps FixYa! If you find this information helpful, please give us a rating and share your experience in a testimonial!
Thank you for using FixYa.com
Green led mains light comes on, battery amber light rapid flash
This sounds sucky, but you may have a power-supply issue. Especially if you have had to repeatedly press the power-button. If the laptop is new, call Toshiba and see if it's under warranty. If not, find a local computer tech to test your power-supply. This problem is less common nowadays, but still an issue for some!
Hope this helps!
-- RT
Give me driver 4600
You can download any/all the Windows XP or Vista device drivers for your model laptop from the Toshiba WEB site from their download page. Make sure you enter the model of your laptop so you can get the correct drivers. Use this link :-. http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp#
1helpful
What is the power button for toshiba satellite pro 4600
hi..the power button is available on the top
of the laptop.It willl be indicated with the
red symbol on it.
check this out..
thank u..
rate me..
Lost installation cd
ask toshiba to send one for a nominal fee.
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
