SOURCE: Sony Walkman NWZ-B105F MP3 wont connect
I first found that when I plugged my player into my computer it registered it as a MTP (Media Transfer Protocol) device and in turn never showed up as a storage device on my computer. I fixed this by going into my Control Panel -> System Icon -> Hardware Tab -> Device Manager button.
Clicking on the "System Devices" tab should have "Walkman" or MTP device. Right click on it and go to properties, now before doing anything it should say "Location -- ------ Location 0 (Walkman)" if not try unplugging the walkman and see if the MTP device you're looking at is removed from the list, just to make sure it's the right device we're looking for.
If you've confirmed it's the Walkman, click on the "Driver tab" and click on "Update Driver...". Then click on the "Install from a list or a specific location (Advanced)" option and click "Next". Now select the "Don't search. I will choose the driver to install." and click next. It should now bring up 2 driver choices, one being "MTP Device" and the other "USB Mass Storage Device". Select the USB option and select next, it will then install your walkman as a USB storage device and after that's done. It should be a matter of unplugging and plugging the Walkman back in and it should show up on your storage options in "My Computer"
SOURCE: remove write protection on a walkman nwz-s616f
I had the same problem after using this product for a month, suddenly it showed the warning of write protection.
I even contacted the sony customer center but to no avail. their answer was of no help at all.
so here is what i did to make it work:
1) First install "QuickTime version 7.2" or later (you can download it from torrent if you are unable to register it, i.e. with a crack)
2) Then install "Windows Media Player 11 " (you can download it from torrent if you are unable to validate it, i.e. if WinXP not original)
3) Now install "Media Manager for WALKMAN" (a compatible software provided by the sony company to interact or communicate with the walkman), freely available for you to download at sony's website.
After the installation, connect the walkman to your computer. Now it should easily add or delete data from you walkman using this software or without it as well.
SOURCE: NWZ-W202 is not recognized by computer with window
i had the same problem, after trying everything i and helping friends could think of, i just wiped my entire pc reformat n started from scratch, once i did that, before installing anything at all, i plugged her in and she workd straight away and has continued to work. HAPPY DAYS
SOURCE: can't play back video on sony walkman nwz-s616F
Hi everyone, I had this problem with the Sony MP3 players I bought for my kids (NWZ-S615F). There's a new (free) video converter from iWisoft (download.cnet.com or easy-video-converter.com) which does the trick. I looked into the others mentioned here and there were some virus/trojan horse concerns but so far this one seems fine. I downloaded the file, then did a virus scan, then ran the application and did another virus scan. I've used it 10-15 times since then and did another virus scan and nothing comes up so looks good. Choose the output file format as the first option under iPod. If it hangs while doing the conversion, try to run the output file before you get frustrated - I've found that most of the time the conversion was completed before it hung and the video plays fine.
I would try another computer if that did not work the unit is what we called bricked, now you could go to sony.com and see if they can help you to try to get thing back in order please do try my solution first if it does not work the unit is defective.
Thanks and please do use the thumbs to rate this solution and advice.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
