Just click on the below link to fix "print unable 32"
http://welcome.solutions.brother.com/BSC/public/eu/eu_ot/en/faq/faq/000000/002500/000055/faq002555_000.html?reg=eu&prod=hl4040cn_all&c=eu_ot&lang=en
This
problem is often caused by the shutter door
sticking in the open position. The solenoid that
pulls the door open has a foam pad affixed to
absorb the shock when the door opens. Over time
this pad gets sticky - possibly due to toner
spills. Some remove the pad, I covered mine with
scotch tape. That way the cushion remains but the
door no longer sticks. You can test it by pulling
out the belt assembly. Look inside to the left and
you'll see the black plastic door, about 1/2" high
and 1.25" wide. Lift it from the bottom to get to
the sensor (which may need cleaning - I used a
damp cloth). It you can get the door to stick
open, then it's likely you found the problem. It's
no big deal to disassemble it from the rear. Just
take out the solenoid and cover it with about 1/2"
by 1/2" of tape. Reassemble the solenoid in such a
way that it pinches the tape so as to keep it from
coming off (the stickup on that tape isn't very
strong). The door should no longer be able to
remain stuck in the open position. If that doesn't
do it you probably have a bad board or solenoid.
I'll bet this is the problem 90% of the time.
I wrote an illustrated technical note on "Print Unable 32":http://www.scribd.com/doc/62071141/Broth...
Oce CX2100 print unable 32
The intructions posted by gadget850 also apply to the Oce CX2100. Thanks you!
