GE Energy Star WCVH6260F Front Load Washer Logo
Posted on Jun 17, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
GE front load washer (clothes)
Washer fills, washes but won't spin. washes back and forth just no fast spin. Since it does not spin , won't drain either. Filed complaint on GE website regarding the location of the filter. I had to clean it after I came home and found my machine still running about 3+ hours after I left it. I took out the sopping wet clothes, removed the front panel and cleaned the filter. I had trouble replacing the panel - pulled a muscle - or something - in my shoulder and am quite uncomfortable. Customer service called and said they felt the filter was reasonably easy to access and had no other complaintsand therefore offered no solution - and suggested I have "someone else" in the household help me to change the filter next time or I can call a service tech to do it...my response was do they really expect their customers to have to make a service call 2x per year to clean a filter??? Would they do that for free??? What if I were a single mom???
Anonymous
Level 3:
Genius:
  • Master 1,122 Answers
  • Posted on Jun 17, 2008
Anonymous
Master
Level 3:
Genius:
Answers
1122
Questions
5
Helped
316448
Points
2771
DOES NOT SOUND PROFESSIONAL TO ME,ALSO REMEMBER IF TUBE WILL NOT DRAIN SOMETIMES THE WATER PUMP GETS CLOGGED OR SOMETIMES THE DOOR SWITCH FAILS,I HOPE YOUR SHOULDER FEELS BETTER,TAKE IT SLOW AND EASY THE NEXT TIME YOU DO IT-MIKE
1helpful
The machine is not spin after wash, motor pump is work, and for wash is turn one shot left and one shot right and stop,...where is the problem???
Reasons Why Your Washing Machine Won't Spin
losangeleswasherdryerrepairservice.com > News
Apr 16, 2012 - When the washer enters the spin cycle but does not start to spin, you will need to see if there is ... West Los Angeles Washer and Dryer Repair Service ....After the water has drained, the spin cycle will start. .... Drive Motor, GE, Maytagwashing machine won't spin, spin bearing, washing machine clutch worn ...
Spin Cycle Not Working on Washer ' ThriftyFun
www.thriftyfun.com/Spin-Cycle-Not-Working-on-Washer-1.html
My washing machine will wash but the spin cycle will not spin or drain the tub what do I do to repair that? By Shelly H. ... Question: Washer Stops After It Fills for Rinse Cycle and Does Not Spin. By henryj ... Our GE washer will not spin when it has a load of clothes. It washes .... I have a Frigidaire stackable washer and dryer.
How to fix a washer that will NOT spin ONLY. THE EASY ...
? 3:56
https://www.youtube.com/watch?v=_8myOfPzGfM
Aug 4, 2012 - Uploaded by Brad Hyman
My washer did not spin but the belt drive worked to agitate the ...How to Fix a Washing Machine That Does Not Spin (Fast and Easy) - Duration: 8:45. ... Washer Top Load Not Spinning - Repair & Diagnostic- GE, General ...Missing: dryers
Feb 09, 2016 • GE Dryers
Front load washer, try to spin, but stops altogether and want wash it fills up but want wash
Make sure that you don't over load the washer. As it starts to spin back and forth it is sensing the load balance as the clothes fall back and forth. If it doesn't sense a balanced load because the clothes can't fall back and forth it will not start the wash process. Refuse your load and try again.
My GE washer #WDSR2080DEWW washer won't spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Washing goes thru fill cycle, and spins, clothes still wet and soap still in machine.
heatman101
GE Washer will wash but won't drain?
heatman101
My ge front end loader washer won`t spin water or pump water out
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
GE clothes washer WHDSE820C1WW started filling itself up and i cant get it to discharge the water out, spin or anything
heatman101 .
1helpful
My font load washer wont fast spin or drain
gimme those older models anytime. their having a lot of trouboe with this front loaders
My font load washer wont spin or drain
You will need to to replace the inverter
GE Adora Front Load Washer
I went to the home depot site and they have various videos that explain about the washer and how it works. This made my understanding more clear as to how the washer works. Thanks!
Top GE Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Virgil Watts
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
