AEG U3100-4 Electric Double Oven Logo
Posted on Nov 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an AEG Competence Single oven model B2100-1-w The oven is not reaching or holding temperature I have noticed the fan is not spinning
Barry Coates
Level 3:
  • AEG Master 3,463 Answers
  • Posted on Oct 02, 2011
Barry Coates
AEG Master
Level 3:
Answers
3463
Questions
Helped
1406953
Points
12766
You need to replace the fan motor assy.
Anonymous
Level 2:
  • Expert 174 Answers
  • Posted on Nov 10, 2010
Anonymous
Expert
Level 2:
Answers
174
Questions
Helped
126435
Points
483
Hi steve sounds like your fan motor is faulty they are not very powerful any resistance in the bearings can stop it starting. oiling the bearings wont help you need to replace the motor also it will have damaged the element no air circulating it will of overheated. an overheated element usually lasts till xmas morning.
My fitted electric AEG Competence oven door has locked and I don't know how to undo it
My oven AEG Competence Pyrolitic, door locked itself...now is locked and appears SAFE ou Lok or error F101..
We never use pyrolitic system or ever locked the oven door..
Could you tell me how do you resolved?
Regards
Hello. I have an AEG electric oven which is
It seems like the element around the fan in the main oven has most probably burnt out and will need replacing.
Hpoe this helps,
2answers
The top oven of our AEG D5701-4 is slow to heat.
Hi it could be the element on the grill it maybe burning out, what slows the grill to get hot quicker. best to turn of the mains or by the main switch. and get a toorch to check around the element or use a continental reader check if it is receving 240volts
3helpful
AEG Competence Oven not working
If you are certain that the element is o/k, and it is not heating, then thwere are 2 possibilitues.
1- the oven thermostat could be faulty, whereby it is giving a feed to the element.
2-some ovens have a fan only setting, as well as heat and fan, make sure that it is not on a fan only setting.
Hope this helps.
Feb 05, 2010 • AEG Ovens
Oven is AEG Competence, single oven, fan assisted, 4 yrs old. Oven doesn't heat. Light ok, automatic cooking settings not switched on, grill working
If the fan is working o/k, then you need to replace the oven element.
This is located at the rear of the oven compartment, behind a removeable cover.
This should solve the prob.
Please leave feed back.
Thankyou.
Jan 06, 2010 • AEG Ovens
1helpful
Timers on my aeg competence cooker
Hi, My Competence B1180-4 digital clock keeps switiching itself off and then back on. This means that the timer etc dosen't work. It is intimitant.
10helpful
Aeg competence b2190-1m oven not heating
If the fan is working o/k, then you need replace the oven element.
To access this, remove inner rear cover of oven, there you will see the circular element.
Unscrew the screws securing it ,and remove element.
Detach wires and transfer to new element, be careful not to lose the wires behind the oven rear, refit element and rear cover.
please rate my solution.
Thanks
2helpful
Aeg competence oven fan not working
If fan has stopped altogether, then you definately need a new one, to be sure you need to disconnect and remove the fan and bench test it.
Hook up a 240v supply to the fan and see if it runs, if not then it is no good..
It does not matter which terminals you connect live and neutral too as it is common to both terminals. do not connect feed to earth by mistake.
Plz leave feedback.
2helpful
Aeg competence b 8139-4-m - oven not heating up
your heating element is probably bad. all u have to do is, make sure the oven is off, pull elem. away from it's holders on the top or bottom of the oven, then pull the elem. loose from it's sockets then, straight out of the oven. take to home depot, or lowe's, or an used appliance store. installation is reverseal.
from sid
Top AEG Ovens Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Are you an AEG Oven Expert? Answer questions, earn points and help others
