Recognises my wifi but still can't connect tom safari/youtube etc
I FIXED MINE THIS MORNING!!!
try this! If your iTouch says you are connected to your network but you can't surf and you've been able to connect in the past...you have to reset your network connections on your iTouch.
Go to Settings
Go to General
Go down to Reset
Go to Reset Network Settings
It will ask for your iTouch Passcode...enter it
Then, hit the red "Reset Network Settings"
After that, go back to "Wi-Fi" in Settings...
...and connect to your network again. It might ask you for your WEP password, if it does, enter it.
The IP Address, Subnet Mask, Router and DNS fields should now have entries in them.
Surf Away!!
Hope that works for you. It worked for me!!!
fantastic stuff, thanks mate your a life saver!!
My Gosh, Thank you so much!!!!
Worked perfectly. Ty
Only the IP Address & Subnet Mask filled in. Still isn't working :(
Okay. Heres what you do. It works I promise!
1. Go to settings
2. Turn off WIFI connection
3. Hold down the power button until it says slide to power off
4. Turn it off
5. Once its off click the home button and while still holding down the home button plug it into itunes.
6. It will say something on your itunes page. Click okay. Then your ipod will go black.
7. Wait and then when it comes back on connect to the internet again
if it doesnt work try reseting your ipod touch
hope it helps!!!!
Okay here is what you REALLY have to do!!!!
go to google
type in "wirelesskeyview download" into the search engine
click on the first link that it shows and download it.
it's completely free and VERY helpful!
its a very short download, extract the file and put it somewhere where you won't lose it because it won't show up in your start menu.
This doesn't require any installation.
Go to where you placed the file and open it.
click on the application and it will ask you to allow/cancel the program.
your network should show automatically and WEP will show next to it in the hex column.
type what you see in the hex AS the network's password on your itouch
It worked for me!!!!!
Dumb question, but did you put in the security code of your network if it is locked? In settings, wifi networks. Seems like I had to do that.
Ive tried all of the solotions
I had same problem. Took it back to Best Buy and they could not connect to their WiFi. Conclusion--bad wireless card. Got money back because they had no replacement. Bought new one at Wal-Mart. It worked perfectly. Solution is do not putz around; return for one with wireless card that works.
Hi my ipod touch says that it is fully connected and when i go on safari it says that it cannot connect. iv tried turning my router off, restoering my ipod, restoring all the setting n when i go to my mums it works fine my mums internet it netgear im really angry because it worked for a month now and now theres no interenet!! help!!!!!!!!!!!! :(
If you have a Linksys router this worked for me. Go to Settings on your ITouch; Wi-Fi; Other; Security; WPA; Go back to Other Network; Type in your network Name at the top (for example mine is GSI); then go down to Password and type in the Personal Key found on the Linksys page after you logged in with your password. Once I was on the correct page I went to Wireless and then Wireless Security and you will see the Personal Key about five tabs down.
I had the same problem and resetting the connection (Solution #3) worked for me. Thanks!
I know this sounds stupid and obvious, but make sure your putting in the passcode to the wireless internet correctly, and if you are then try them in CAPS.
i know it sounds obvious but that was all my itouch needed, plus another solution is when you click on the blue arrow next to your chosen network, then look under ip address MAKE SURE THAT DHCP IS HIGHLIGHTED!
Hi I had the same problem. My sons I touch had always connected to internet no problem until last night. It seems its been a common problem. Its Fixed now.
What I did-
1-SETTING
2- WI-FI
3. CLI8CK ON YOUR WI-FI CONNECTION ON THE ARROW TO THE LEFT.
4.FORGET THIS NETWORK
5. DISCONNECT ROUTER AND UNPLUG
6.RE-CONNECT ROUTER
7.SETTINGS
8- WIFI
9-CLICK ON YOUR WI-FI
10. under IP address click on STATIC
11. then I copied all the number details off my other iphone in the wi-fi settings ip address & Subnet Mask,& Router & DNS & Search domains
12 Go back to main screen by pressing your main button at bottom of phone.
This worked for me and was better than resetting all settings and my sone loosing his progress in games etc. Good luck!!
Go to settings... and view the connection... select the little arrow to the right of the name of the connection.. and select "forget this connection" turn the wifi off... then back on.. and connect back on the network and it should work. it fixed my mine. i had the same issue. goodluck
Hey my IPOD willnt connect to the internet it kicked me off and when i went to go back on it said something like unable to connect and stuff i trided reset it but it didnt work should i just see if i can retun it LET ME KNOW!!!!!!! Thanks
I HAD THE EXACT SAME PROBLEM! RESET YOUR SETTINGS THAT WORKED FOR ME.
I did what moniquet said and it still doesnt work, itouch is brand new, has one week and cant maanage to cnnect it.. any other suggestions? help please!!! :(
Ok..so next to the wifi you connected, there's a little blue arrow button and press dat button...after dat, go down and you will see renew lease and press dat...dats how i got mine..hope it worked :)
Okay so i just bought and i touch from a friend and went home and 'connected' to the WiFi but ounce i went to safari it wouldn't bring anything up it keeps saying 'safari cannot open the page because it is not connected to the internet'.....ive tried almost everything-_- i restored the thing, did the whole reseting the network connections and neither of those things work...I mainly baught this ipod for the internet capabilites and am super sad that it not working....PLEASE HELP!!!
The internet used to work but now it has stopped:( i have tried mostly everything, but to b ehonest i am horrible with computers and ipods.. can someone tell me after you click the little blue arrow and this all pops up: IP address, Subnet Mask, Router, DNS, Search domains, and client id... whats suppose to go there? am i suppose to enter stuff for each of those? and if so, where do u find all of tht information??!
I compared my ip address and subnet mask with my dad's iphone and its totally different,on my dad's phone the internet works but for my itouch it doesn't
HELP PLEASE, I have to hold my 1st gen ipod right next to my router, touching ipod to router, in order to get a connection, if i pull the ipod even 6 inches away from my router the connection stops. Someone please help..... thanks
Hey moniquet a big thanx. Wow it worked beautifully! NOw why cant all things work like this, lol! NOw I feel kinda dumb because it was a simple solution, once you have the tools. Thanx again and have a good one!
ss1122
Omgg, thankyou so much 'moniquet', mine wasn't working even tho it was connected to my WiFi, but now it's fixed, thankyou sooo much :D x
I suggest u just get some fried chicken and put it into te chicken monster
Cuz u ****
same - can;'t get to any screen to enter my key number
it recognizes my wifi connection but no signal bar or anything. same router works for laptop and computer upstairs but nothing on the touch.
itouch wont connect to internet or update the weather
no internet connection
iTouch won't connect to internet,my router light is on but safari or your tube is not
Same thing -it recognizes my wifi and looks like its connected but no signal bar or anything. same router works for laptop  but nothing on my ipod
my itouch says its connected to wifi...but keeps saying unable to connect to server?? why!!
same problem . damn this is irritating ..
connected to wifi but wont do anything
Omg this is so annoying. I'm connected to my household WPA2 wireless network. The iPod says I'm connected, I have 4 signal bars. But when I try Safari, it says "Safari can't open the page because it is not connected to the Internet". But I am. My other computers work great. I've never had this problem before on the iPod and I have no idea what caused it or how to fix it.
deleting and resetting my connection did not work, tried that before I used google
I´m having the same problem!!!Â
I am having the same problem, I have tried turning it off and back on and disconnecting and reconnecting and nothing seems to fix it.
i connect but i get no bars
I can put in my wireless router information and password and then it says I am connected but nothing works. My laptop is connected so I know it's not the router. It only worked this weekend and hasn't worked since.
i hav the same problem, my itouch use to be able to connect, but now it wont at all, i know its not the router, and even when it says that its connected it still wont work.
why won't my itouch connect to the internet work
This is so annoying!
I think I've tried everything possible!
It says I'm connected.
And then it will ask me when I go in to itunes which wifi i would like to connect to and I hit the one I want.. and then it says "unable to connect to itunes" or server or whatever.
GGJIDFJIEJSJLSe.
I just purchased an itouch for my daughter turned it on and it did connect to the web at my house. But when she got home and tried it wouldn't connect. Please help!!!
Omg, this is so fucken annoying!! the wifi asks u to enter the password and i entered it, but then is says unable to connect!! **** man, wat the hell is the problem with these ipod touches!
You would think this would be easy
I am extremely disappointed in apple. This is like a typical microsoft thing to do. Promise you the world and make it impossible to achieve. tisk tisk tisk Apple
i have connect it to the wifi from my house and then i go to the safari and it says that it cant connect because i dont have it connect it and then i go to settings and it says that it is???
idk it sucks
Im connected but it wont let me access my internet.
my itouch says can't connect to server!!! will somebody help me!!??
have exactly the same problem cant connect it and ive tried resetting my while i touch :(
Ive been doing a search on this topic.many people have the same problem.and not many solutions.well none to be specific.i have the same problem.it shows that im connected but when i try to go on safari.or youtube.etc it says cannot open page.because internet is not connected.when in fact at the top of my touch it shows a full internet connection.this is a pain in the a$$.anyone know what i can do to fix it.or have an idea what it can probly be
Go to Settings
Go to General
Go down to Reset
The IP Address, Subnet Mask, Router and DNS fields should not have entries in them.
Surf Away!!
whoops! I meant to say that the
IP Address, Subnet Mask, Router and DNS fields should NOW have entries in them!!! Sorry.
I can't connect to my wifi. I tried to reset it, but it still says (unable to join to the network). I have been on it before, and I can use the same wifi on my brothers i touch. So I know the password and service is fine. That means the problem lies with my i touch. Help me please!
mine connects for aout 15 seconds then disconnects but even while it says its connected i cant get onto safari.
have westell 327 and can not get it to connect to itouch. itouch sees the name of my network, but when itouch asks for a password I don't know what password to use. I tried the administative/user name I used when I installed westell 327 but no luck. What password should I be using -- where will I find it?
When I try to connect, they ask me for the password, I type it in perfectly respecting the capital letters and all but it just won't connect...What can I do ???
i have 3 full bars of internet service and it says that i have the internet but it still wont connect help
i have the same problem.. it worked b4, my laptop in on right now and i have internet.. but the i touch says im connected but when i go to safary it sais im not so idk
fuckin mine is doin the same as all of urs
mine says server stopped responding..... WTF
Hi! I have a problem w/ my Itouch. I'm trying to connect my internet w/ my Itouch. The problem is that it said that its unable. It also ask me for a password, is it the wep-key? When I find a Wi-fi w/ no lock I get the internet but with my own... I can't! its lock...so.... what should I do to unlock it?
someone help please
Im in my network and have Wi-Fi but i cant go to anything that with internet i select my network ans ip address and subnet have writing next to them but the rest dont. I've been waitig so long to get this damn thing and now i cant get it to work please help!
It recognizes my server thing (linksys) but wont connect to internet
my internet server stopped responding what can I do?
same problem!
i have more or less the same problem except my 2g finds the router but cant connect it just keeps loading ....it worked fine this morning
my ipod cant connect to network right next to router
it says im connected to the internet but i cant get on anything. my dns and router isnt filled in. how can i get the router and dns numbers on a pc?
all of a sudden my itouch is saying it can't connect to the internet, it's ben 2 days now and my lap top is connected fine.
my iTouch shows that i have connection to Wi-Fi but i still can;t connect to anyhting on the internet!
my ipod touch says that it is connected to a network, but then none of the apps or internet will work. i dont know wats going please help!
my ipod touch has a lock symbol next to the network but I put in the modem password andit doesn,t work
AHH!! I type the password in and it says i cant connecTTT11
my ipod touch wont connect to the internet
my itouch was working fine, but now my wireless network says its connected, but won't open up youtube or safari! help!
i can get internet from my god damn school but cant get it from house its ******** and Ive tried pretty much everything.
I was able to go online for a while after i got my itouch but now it says, "Safari cannot connect to webpae becasue its not connected to the internet". I've tryed everything
OMG i was watching a youtube video when my internet stopped working and i was freaking out because it's my dad's network i connected to plus he let me through the mac filter and only today did this happen and it just stopped working and i tried to renew lease and everything but i was connected but when i went to something online it said i was not connected to the internet like the app store and i was like wtf man im connected right now and i kept checking my settings and going through everything i could to figure out the problem but nothing was working. I mean MY COMPUTER WAS ABLE TO CONNECT BUT MY ITOUCH COULDNT... big WTF right there. CAN SOMEONE HELP MA SITUATION
same.
My ipod is connected to internet with 3 bars, but i cant do anything like safari/ifunny/youtube/ ect. iv tried reseting network, unpluging my router and plugging it back in and it still dosent work, i did forget this network and reset networks and turned off wifi for an hour and turned it all back on and still didnt work... if you find a way that will work please send me an email to fix it at [email protected] , thanks
