Got an error code indicating a problem. Started washer to pump the water out. When I tried to start it again to run the diagnostics in was completely dead - no lights lit up. Is there a fuse or reset button that controls the main control module, or will I be buying a new brain box right up front? I actually think the cause of the original error code is a leaky pump - signs of water streaks on the pump windings but it does me no good to worry about that when it won't even light up anymore.
No power supply issues - GFI etc. (other items work on this circuit). I was thinking or maybe hoping an internal fuse or miniature circuit breaker type protection. Is that possible?
boyfrederick
is it on a ground fault breaker if it is check the outlet switch for a reset switch you know one of those buttons you push on yhe outlet
