Please follow the below steps, i hope your problem is resolved :-
Make sure that your phone's blue tooth is out of hidden mode and , it now shows up as shown to all, in the connectivity settings.
Make sure that you delete the pairing from the other phone , via it's blue tooth settings, if you are not using the phone and it's switched off , then you don't have to worry about it.
Switch off the bluetooth and restart it , so that it's ready to accept new connections.
Now go in your blue tooth option and search for a new paired device , it should reflect your Jabra blue tooth.
If the above method does not work , sadly your phone does not support the Jabra blue tooth.
You should also try connecting this blue tooth to someone else's nokia phone to check compatibility , if it's compatible with the other models, that means X3 is an exception to this compatibility.
The Blue tooth pairing device on Nokia E71 is a little bit complicated. Many people had problem pairing the device as it has two ways to access the Blue tooth menu. Firstly, you can go to Menu, Tools, Settings, Connection, Blue tooth, you'll reach a screen that has everything (except the ability to pair a device). Secondly, you go to Menu, Connectivity, Blue tooth, you'll get the exact same screen, except that you'll have the additional "tab" and be able to pair the device.
In order to set up your blue tooth device to your phone you first must turn your blue tooth power to on in your phone menu then you must turn your blue tooth device into discovery mode.this usually is done by holding the power on for 6 to 10 seconds and a solid light will be on,then in your phone menu you can add or search for blue tooth device if you have your blue tooth in diuscovery mode the two will pair then you must enter a pin or pairing code,most manufatures of blue tooth devices use a 4 digit factory pin or pairing code they are as follows 0000,1234,9999 or 1111 enter the code and they will pair ,once paired it might ask you to connect ,selet ok or yes and your in business, i hope this helps
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Instructions
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device. Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Either the the blue tooth is not pairing well with other devices,
or
The blue tooth is corrupted.
When pairing phones together, make sure you pair the phone properly before you can use the blue tooth with other phones, because if you don't pair properly with another device, you will not be able to send or receive any data.
If the blue tooth is corrupted all you need to do is to flash the phone, that is the only way to restore the blue tooth back to be working.
has the radio got blue tooth installed , as some say "blue tooth ready" on box but need an additional piece of kit to get it to work, ..........if it has then you need to find the BT function on the radio, either menu/ sorurce button and search with your phone , make sure phone is "visible" in the blue tooth mode
-First you must "enable" your blue-tooth on your handset.
-Secondly you need to make set your blue-tooth feature to "always visible" (this setting is within your blue-tooth application).
-Third, you need to search for all available blue-tooth devices within your range.
If the kiosk shows as an one of the available devices, try to pair with it. (Note: If your blue-tooth feature prompts you for a pass-code, enter 0000.This also applies if the kiosk prompts for a pass-code.)
If you have followed all these guidelines and you are successfully paired with the kiosk, Congrats! At this point, you will need to send the kiosk all your current pics. Your blue-tooth should give you an option to send and what information your a restricted to send.
Cannot pair a iPhone 4 to the ds6511-2, is it compatible?
