The problem is caused more than likely by a defective magnetron, "heats food" because it is the heart of the microwave oven it is the most expensive to replace, it is cheaper in the long run to buy a new unit rather than have it repaired.
Many possiblities, but first thing to check is door switch. Unit will not run if door is not closed. Door switch is safe feature. Remove outer casing and check to see if switch is broken or miss alined.
There could be a main fuse inside the unit. Mine has one that is ceramic, sort of like the old glass car fuses but ceramic instead of glass. Digi-Key has all kinds of fuses, www.digikey.com.
Not knowing what country you're in, I'd say the best bet is to contact the dealer from whom you purchased it to see if they have contact information for Daewoo.
THe microwave has to be removed from the wall and then the outer cabinet has to be removed to get to the bulb. Do not do this with the unit plugged in and do not do this if u don't know how to work on a microwave as there is a shock hazard.
