SOURCE: fork seals
ZERO air pressure on these forks those air valves are to get rid of any built up pressure in the tubes. I also have a 1990 851 love it! What weight of oil are you running and how much are you putting in?,,
SOURCE: fork
loosen top pinch bolts loosen caps remove forks remove springs , fill according to manual level . re-instal everything .,,,
SOURCE: i need to know the fork oil level for a yzf250
Factory service manual says 19 ounces > Manual Page 2-12
You can download a free PDF of a factory service manual at this web site >
http://www.carlsalter.com/motorcycle-manuals.asp
Please rate this answer. Four diamonds would be nice. Thanks!
SOURCE: I changed the fork seals but i dont know how much
fork oil type -fork oil#10, oil capacity each leg 388 ml for E-01,28 33 models and 392 ml for the other models standard oil level 142mm for E-01,03,28,33 138mm for the other models
SOURCE: replacing fork seals and need to know amount of
Outer cartridge on the twin chamber Showa fork for an RM250 uses 350ml of 5W oil.
This doesn't seem to be a digital camera problem. You are more likely to get an answer if you post in the correct subject area.
