Sharp VC-A410U VCR Logo
Posted on Jun 15, 2008
No remote Remote for Sharp VCR (vc a410) was lost in the move, and I don't know if it can work, or be set up, without one. HELP!
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Jun 03, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
680
Points
Check e-bay for SHARP RRMCG1236AJSA TV/VCR REMOTE
There are some for under $10 total
2 Related Answers
bshldn
Loretta Northcutt
  • 736 Answers
  • Posted on Jan 07, 2011
SOURCE: Have a Sharp VC-H810 vcr
Unfortunately if there is no menu option to do that or button on the VCR you will need one of these remote controls
http://www.replacementremotes.com/SHARP/Buy-RRMCG1236AJSB-VCR-Remote-Control.html
or
http://www.replacementremotes.com/SHARP/Buy-RRMCU0002AJZZ-Remote-Control.html
gopakumarg43
  • 76851 Answers
  • Posted on Aug 03, 2011
SOURCE: What is the remote control code for the Sharp
Hello
Three digit universal remote codes for Sharp TV are:
004/ 009/ 079/ 095/ 111/ 112/ 114/ 122/ 123/ 124/ 173
Four digit universal remote codes for Sharp TV are:
0079 0123 0063 0020 0004 0009 0226 0266 0006 0095 0122
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
OK
What is the remote control code for the Sharp VC-A410 VCR?
Hello
Direct Code Entry
OK
Have a Sharp VC-H810 vcr without remote. Is there a way tosiP, SP etc without a remote on the vcr? Thanks in advance!
or
I have a Sharp VC-A410 and when I try to press play then nothing happens. I tried pressing play, rewind, and fast forward and it makes the sounds like it is processing my requests but nothing shows on the...
It is likely a defective rubber product, ie belt or idler tire. Here are some links to a company that still carries VCR parts and supplies. Hope this helps.
Belts: http://www.electronix.com/advanced_search_result.php?search_in_description=1&keywords=vcr+belt&x=0&y=0
Idler Tire: http://www.electronix.com/advanced_search_result.php?search_in_description=1&keywords=vcr+idler&x=0&y=0
Need the right code for my sharp vcr vc-h810
The codes to use for a Sharp VCR and a URC-3021 are 0048 or 0807.
To setup your URC-3021 for the VCR, these are the steps:
1. Turn on your VCR .
2. On the remote control, press VCR once.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Enter the first four-digit code for your device. If performed correctly,
the LED will blink twice. If the LED did not blink twice, repeat steps 2 through 4 and enter the same code again.
5. Aim the remote control at the device and press POWER once. The device should turn off.
Hope that helps.
Need operation manual and remote control for Sharp VCR VC-H822
All I am looking for is the owners manual and a remote control for the VCR I purchased at Goodwill--Sharp model VC-H822.
Thank you and have a great day.
David
1helpful
Sharp VCR vc-a41 tuning to TV
do you have cable? if yes both tv and vcr should be on ch #3 (to record).......ok no cable you are already set up look at tv right....just need to record..you need your vcr remote.....turn on vcr...press the menu...go to ch settings..auto scan will look for and lock in your channels...also make sure the air/cable selection is on air (unless connected to cable)....hope this helpful....feel free to rate
Vcr not working
my sharp vcr VC-H91cannot be switch on. only the standby light is on
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
