LG RUMOR Cellular Phone Logo
Posted on Nov 07, 2010
My phone's time has not changed with the time change. It still reads the old time. How do I change it so it reads the correct time?
Randy Osborne
Level 1:
New Friend:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Nov 07, 2010
Randy Osborne
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
8
Questions
Helped
650
Points
24
The Time on most Cellular Phones is controlled from the Network, so there is no way for the user to manually adjust it. Try turning the phone off for a few seconds, and when it boots back up, the time should be updated. If not, it might take another hour or two, but it will eventually be correct.
hope this helps
R
How do I change the Date and Time displayed?
You log into the Phone administrator settings, Go to General, Select Date and Time and correct them for the entire phone system.
To Log Into System Programming:
1. Press FEATURE * * 2 6 6 3 4 4
2. Enter Password: 2 6 6 3 4 4 Display will read: " A. Configuration"
Using the navigation keys, as displayed below, follow the next simple steps:
3. Press: NEXT Display will read: "B. General Admin"
4. Press Show
5. Select Date and Time and Press Show Correct Date and Time then press release. Let me know if you have any other questions.
7helpful
How do I change the time on the display on my NorStar M7310 phone?
Changing the time on a Norstar system must be done using a display phone. Using a M7310, M7324, or T7316 the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
1.- To enter programming mode press "FEATURE" and "* * 2 6 6 3 4 4"
2.- Enter password (default = 266344) - display should read "Terminals & Sets"
3.- Press "NEXT"(bottom right arrow) 5 times - display should read "Time and Date"
4.- Press "SHOW" (top right arrow)- display should read "Hour:___"
5.- Press softkey "CHANGE"
6.- Enter hour - display should read "AM OK or Change"
7.- Select AM or PM
8.- Press "NEXT"(bottom right arrow) - display should read "Minutes:___"
9.- Press softkey "CHANGE"
10.- Enter minutes
11.- Press "NEXT"(bottom right arrow) - display should read "Year:___"
12.- Press softkey "CHANGE"
13.- Enter year
14.- Press "NEXT"(bottom right arrow) - display should read "Month:___"
15.- Press softkey "CHANGE"
16.- Enter month
17.- Press "NEXT" (bottom right arrow)- display should read "Day:___"
18.- Press softkey "CHANGE"
19.- Enter day
20.- Press "NEXT" (bottom right arrow)
21.- Press the Rls key
NEED TO CHANGE TIME ON PHONE DUE TO DAYLIGHT SAVINGS PHONE IS T7316E
Changing the time on a Norstar system must be done using a display phone. Using a M7310 or T7316 the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
7.- Select AM or PM
10.- Enter minutes
11.- Press "NEXT"(bottom right arrow) - display should read "Year:___" 12.- Press softkey "CHANGE"
13.- Enter year
16.- Enter month
19.- Enter day
2helpful
Cannot change time on the nortel ICS phone
7.- Select AM or PM
10.- Enter minutes
13.- Enter year
16.- Enter month
19.- Enter day
1helpful
Have no manual and need to change the time on the phone
1.- To enter programming2.gif mode press "FEATURE" and "* * 2 6 6 3 4 4" 2.- Enter password (default = 266344) - display should read "Terminals & Sets" 3.- Press "NEXT"(bottom right arrow) 5 times - display should read "Time and Date" 4.- Press "SHOW" (top right arrow)- display should read "Hour:___" 5.- Press softkey "CHANGE" 6.- Enter hour - display should read "AM OK or Change" 7.- Select AM or PM 8.- Press "NEXT"(bottom right arrow) - display should read "Minutes:___" 9.- Press softkey "CHANGE" 10.- Enter minutes 11.- Press "NEXT"(bottom right arrow) - display should read "Year:___" 12.- Press softkey "CHANGE" 13.- Enter year 14.- Press "NEXT"(bottom right arrow) - display should read "Month:___" 15.- Press softkey "CHANGE" 16.- Enter month 17.- Press "NEXT" (bottom right arrow)- display should read "Day:___" 18.- Press softkey "CHANGE" 19.- Enter day 20.- Press "NEXT" (bottom right arrow) 21.- Press the Rls key
1helpful
How do i change the time on a norstar m7208 phone
1.- To enter programming mode press "FEATURE" and "* * 2 6 6 3 4 4" 2.- Enter password (default = 266344) - display should read "Terminals & Sets" 3.- Press "NEXT" 5 times - display should read "Time and Date" 4.- Press "SHOW" - display should read "Hour:___" 5.- Press softkey "CHANGE" 6.- Enter hour - display should read "AM OK or Change" 7.- Select AM or PM 8.- Press "NEXT" - display should read "Minutes:___" 9.- Press softkey "CHANGE" 10.- Enter minutes 11.- Press "NEXT" - display should read "Year:___" 12.- Press softkey "CHANGE" 13.- Enter year 14.- Press "NEXT" - display should read "Month:___" 15.- Press softkey "CHANGE" 16.- Enter month 17.- Press "NEXT" - display should read "Day:___" 18.- Press softkey "CHANGE" 19.- Enter day 20.- Press "NEXT"
How do i change the time on my Moto W370 cell phhone
You can't change the time the phone reads manually, when you are in service area the time will automatically change to the correct time.
2answers
HOW DO YOU SET THE DATE AND TIME?
It should be in 'settings' on your cell phone menu. Search around your phone. It could also be in 'organizer'. On my old one, it was in 'organizer', and once I went there, there was a 'set date and time' button. Here is the answer from the Vtech website: "Make sure the answering system is on. Press [Time/Set]. The system will announce the current clock setting, then announce "to set date and time, Press Time/Set". Press [Time/Set]. Press [Change] until the system announces the correct day, then press [Time/Set]. Press [Change] until the system announces the correct hour, then press [Time/Set]. Press [Change] until lthe system announces the correct minutes, then press [Time/set]. The system announces the current clock setting. Note: You can press and hold [Change] to advance the mninutes in increments of ten. "
7helpful
2answers
Change home screen display
Press the * key to switch back to date and time. Also, the SHIFT button on top will change the STA EXT FEAT.
The only way I know of changing the name is in the main phone system.
Top LG Cell Phones Experts
vince
Steve Sweetleaf
Steve Sweetleaf
nexrad_chris
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
