Yes you can purchase the power supply and base control for you creative product.
You can go to the website www.buy.com or you can select the below link to go to the webpage directly.
http://www.buy.com/retail/usersearchresults.asp?querytype=home&qu=Creative+Labs+Inspire+T2900+power+supply&qxt=home&display=col&cb=422451212
You just need to type in as what you want in the search box and then select from the categories available. Free shipping is also available.
Hope it Helps.
Regards
Anand Sachan
click start control panel sounds and
audio,volume,advanced,speakers select the appropriate speakers from the drop
down list or navigate to the device manager scroll to system devices + to
expand,system speaker right click properties then select use this device
(enable) also you might check
the speakers plug/outlet is
usually at the back of the computer you will have to open up the computer
to check the lead attached to the rear of the input plug make sure the
connection is good
try cleaning your computer of dust using a fine air blower from a
compressor making VERY sure that there is no MOISTURE in the air line
specifically around the sound card and the CPU central processing unit dust
causes static to build up in a computer
if you need more help with this posta reply
hope this
helps
