NetGear WG111T 802.11g/b (E82321) Wireless Adapter Logo
Posted on Sep 29, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I instal my wireless adapter and thats work fine with my router. Its says that is connected, but I have error message from network that computer cant find netgear and my network is unidentified. If I look at the properties of usb dapter I can sent but isnt recieving. Also is saying that is just limited connection. Have that somethink to do with ip adrress?
starvin
Level 2:
Novelist:
  • Expert 208 Answers
  • Posted on Nov 27, 2017
 starvin
Expert
Level 2:
Novelist:
Answers
208
Questions
0
Helped
61189
Points
421
Right-click on the Wi-fi icon in the bottom right corner of your computer display and select "Troubleshoot problems". Wait while the Windows Network Troubleshooter tries to identify and fix the problem.
5 Related Answers
Anonymous
  • 15 Answers
  • Posted on Mar 29, 2008
SOURCE: Netgear WPN111 wireless adapter won't connect
Is the computer Windows 98 SE [Second Edition] ?
What is the exact error message that you get ?
Anonymous
  • Posted on May 18, 2008
SOURCE: Netgear usb not getting IP Address
I've just had a similar problem with my WG111T connecting to a Tiscali provided Thompson ST585 router.
My problem was that my WG111T was reportedly connecting OK to the router but that then the router would not assign an IP address to the PC.
I figured out the following - download the latest WG111T driver from Netgear (I used 2.1 from http://kbserver.netgear.com/products/WG111T.asp).
Follow the instructions to deinstall your old driver and to re-install the new.
THIS IS THE IMP BIT. When the Netgear instalation process gives you the option to use the Netgear config - it;s marked as (recommended) then DO NOT pick this. Instead pick the std. Win XP config option.
This then meant that I could control the input of the security key myself.
This worked for me!
Why? Well i'm guessing here but I think it's to do with differences in WEP / WPA-KSP.
Anyway hope that helps
Anonymous
  • 120 Answers
  • Posted on Jan 28, 2009
SOURCE: Netgear WG111 USB Adapter won't work with service pack3 installed
http://kbserver.netgear.com/release_notes/D102534.asp
Reinstall the driver to the WG111 (after SP3 is installed).
Anonymous
  • 1272 Answers
  • Posted on Aug 04, 2009
SOURCE: Netgear WPN111 RangeMax Wireless USB Adapter won't stay connected
Please let me know about the model number of the wireless router and the operating system installed on the concerned computer.
Anonymous
  • 854 Answers
  • Posted on Aug 16, 2009
SOURCE: Netgear wireless N USB adapter wont connect to my netgear router
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
For wireless N USB adapter
Wireless Adapter Installation
A. Install the software.
Note: Firewall and anti-spyware need to be disabled. They sometimes treat software installation as a behavior of a spyware and therefore will prevent installation.
Windows XP:
1. Please power on your computer. Allow the operating system to boot up completely and log in as needed.
2. Insert the NETGEAR adapter Resource CD into your CD-ROM drive. The CD main page shown at the right will then load.
3. Click the Install Driver & Utility.
4. Please make sure that you follow the Install Shield Wizard steps. Click Finish when done and turn off your computer.
Windows 2000/ME/Win98SE:
Note: Windows 2000 may require you to be logged on with administrator rights.
2. Insert the NETGEAR adapter resource CD into your CD-ROM drive. The setup page will then load.
3. Afterwards, click on the Install Driver & Utility link.
4. Make sure to follow the Install Shield Wizard steps, and click Finish when done to restart your computer.
B. Install the adapter.
Windows XP:
1. Please make sure that you shut down the PC first and then remove the power cord.
2. Please insert the NETGEAR adapter into the available expansion slot.
Note: If you have PCI adapter, connect the antenna to the adapter, making sure the antenna is in the upright position.
3. Reconnect the power cord and reboot the computer.
4. When the Found New Hardware Wizard displays, please click on Next and then follow the prompt. If you are prompted with a Windows XP Logo testing message, just click on Continue Anyway.
5. After the installation completes, click Finish to close the wizard.
2. Insert the NETGEAR adapter into the available expansion slot.
4. On the Found New Hardware Wizard, click on Next, then follow the prompt to proceed.
5. After the installation completes, click Finish to close the wizard. Please make sure that you can see the NETGEAR icon located at the lower right portion of your computer screen.
Note: If Windows displays Digital Signature Not Found warning, click Yes to continue.
C. Configure the NETGEAR adapter.
1. Please Double click on the NETGEAR icon on the right lower end portion of your computer.
Note: If you do not see the icon, click on Start and go to Programs. Locate the NETGEAR Utility and click on the NETGEAR Smart Configuration Utility.
2. Click on the Networks tab.
3. Click on the Scan button.
4. Select the Network Name or SSID of your wireless network.
5. Click on the Connect button.
6. You will be directed to the Settings tab.
7. Type a name for the Profile.
8. The Network Name (SSID) will be the same with your wireless network.
9. Make sure that the Network Type is set to Access Point (Infrastructure).
10. Select the Security that you are using on your wireless router.
11. Click on Save Profile.
12. Click on the Apply button.
1helpful
Netgear wirless - installed on toshiba satellite a45 - S151 will not connect to internet router = comcast - linksys also causes conflict with connection of other wireless computer
Presumably, you have configured your wireless router:
* SSID (your "network name")
* encryption-level ('WPA' or higher security)
* password for your network
With that information, any wireless device (iPod Touch, iPhone, NetGear wireless adapter) should be able to connect to your wireless router.
Exactly what error-message are you getting?
1helpful
2answers
Laptop cannot aquire network address from wireless router
If you connect the computer to the router , it works.
That means the wired connection is OK.
Open the set up page of the router check the wireless settings of the router.
I think your network is secured and you are not typing the correct network key.
just open the router set up and check the wireless settings .
Make sure that the DHCP server on the router is enabled
Click Here for step by step solution
1helpful
Bought a G Wireless USB Network Adapter, on install when it asks to plug it in the computer cant find it, then I get a error message that I need to instal the network card
To configure the wireless router, it needs to be connected to a computer with a LAN cable. Therefore the computer needs a LAN card and the LAN card driver installed and if you need to connect a laptop or computer to the router by wireless then the laptop or computer needs a wireless card plus the wireless card driver.
To configure the wireless router and wireless cards in the laptop or computer, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Cant connect to the wireless network
You are not able to connect to the wireless network ?
Check the wireless settings of the router.
Is there any other wireless computer online ?
If yes then you will need to check the settings of the adapter.
Do you get any error message when you try to connect?
Click Here for step by step solutions
I was once connected fine to my router via my D-Link DWA-110 but now I cannot connect at all. Ive done everything I could think of but still dont' know whether its my router or the USB wireless adapter...
are you getting any error message when you try to connect to the wireless network ?
If you have any other wireless computer working then the router must be working.
If you do not have any other wireless computer or device in the network then you can try to change the wireless settings of the router.
6answers
Dell 3300 adapter
Let me recap, just one more time.
Your wireless router,
You updated the firmware(most have out dated firmware from sitting in the warehouse)
Broadcast SSID
Using WPA-PSK(TKIP) Security
Mixed mode(b and g, n if available) This is needed for wireless devices to work properly.
Channels 1, 6 or 11. These channels are the channels most wireless devices work on the best(I use channel 11)
Now for the printer. Download and run this patch to completely remove the printer from your computer.
The patch is password protected. The way around the password protected zip file is to open the zip file with Winrar or 7zip(.exe file)
Restart your computer.
After router is done, now setup your wireless print server/printer.
3300 Utility
3300 Firmware
Attach the 3300 to your computer using the USB Cable and insert the 3300 disk. Follow the instructions. It should ask you for the network ID, type of security and password.
Download the proper drivers.
XP Drivers
Vista 32-bit Drivers
Install the drivers, choose network, choose I'm using a wireless print server(if you do not see this, then choose add printer and you should see it then) and follow the instructions.
Thanks for contacting Fixya
1helpful
Ethernet adapter error during install
Your ethernet adapter might be disabled. Go to Control Panel > Network Connections and look for Local Area Connection. Right-click it and choose Enable. Or go to Device Manager and Enable it there. If that didn't help, try to use a different Ethernet cable.
1helpful
2answers
No Active Internet Connection
If you want to use the wireless portion of your router, you would need a wireless adapter installed on your desktop. If you are getting internet on your desktop then this means that your wired connection is fine to the router is fine. The WMP54G adapter will work with your router, however if you are not planning on connecting to the internet wirelessly through the router then there is no need to purchase the adapter. Hope that this helps you out.
Serge C.
Cannot connect to wireless network
may be your router needs a firmware upgrade.
check the router's website.
and make sure the router and the wireless card are both using the same 802.11 protocol
Installed Linksys G router successfully on my own computer. Now I'm trying to connect a second computer for wireless internet and I'm getting an error message saying: The wizard cannot create a wireless...
1 make sure the wireless adapter is on.. (laptops have on off buttons for wireless)
2 make sure the drivers are installed for card in laptop
if not reinstall them..
check in device manager look for ! or ? in there if you see unknown device or cannot start messages reinstalled that device..
Top NetGear Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
