In back of the refrigerator behind a removable panel you will find a hose going into the drain pan under the refrigerator. Check and make sure there is no obstruction in the hose which would back up water into the freezer. After the drain hose is cleared the freezer should be defrosted and ice cleared from the drain area in the back. You can direct some hot water with some bleach in it through the drain to insure it flows into the pan.
It is somwhow hearteneing to see that someone with the same leaking problem has found this website on the same day I have. The manual says to pour about a cup of hot water down the drain tube (towards the back, just behind a ridge obviously designed to retain some water) every now and then as maintenance. I have done this many times. It used to help, but does not seem to be working anymore. Where does the water go when it drains down that tube?
new in 2011, french doors, freezer on bottom
