1997 Volkswagen Jetta Logo
Posted on Jun 15, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Anti theft system -can't start car
Trouble staring car with key, anti theft security system won't allow ignition to start car but can be bypassed at starter. Radio also won't work, screen shows 'safe'
  • junkyardjeff Jun 15, 2008
    seems to be a factory vw system.
    im not sure where to locate it.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 25, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1421
Points
The price is forbidding our small income expenses. . .BUT if you can
determine my explanation below that your bypass is compatible with ours?
We, I, my wife and baby, are confined in the seculed place in Hayfork
mountains. . .I am seeking for main stand-alone switcher that turns off
against fuel pump, against inner dome light, against rear trunk lid light,
against auto transmission and against four door lock actuators . . .I
successfully made it run with bypass starter relay and hot wired down to
gas tank pump and it runs well but "service immediately" light stays on..
and auto transmission starts on 3 rd gear that stalls engine, it wont start
on second gear. . .when arrived home on uphill road it wont go up so I
drove it on reverse and finally parked here. . .
I KNOW it is a few steps ahead where stand-alone switcher are. I am going
to follow the dome light's wire down to the place where relay-switchers
are. . or follow gas pump wire that I assume can be very hard way to do. .
but before I go ahead that if you can tell me where those switchers for
A/T, fuel pump,inner lights, doors are located?? in 1998 SL1 ? that would
really save my searching . . . Your tips without having to purchase your
bypassing kit would be greatly appreciated.
Sincerely, Donald
Anonymous
Level 3:
Genius:
  • Master 1,847 Answers
  • Posted on Jun 15, 2008
Anonymous
Master
Level 3:
Genius:
Answers
1847
Questions
Helped
553199
Points
4940
There is some issue with ur anti theft sy.
  • Anonymous Jun 15, 2008
    chk the mannual for the anti theft sy and try disableing it. it works i also had the same issue 2 yr back
    may i know the make of Anti theft system and the model no#?
How do I bypass my 2001 Ford Taurus anti theft to start my car without a key
Tampering with the anti-theft system can lead to damage to the vehicle or may even be *******. If you have lost your key or are having trouble starting your vehicle due to the anti-theft system, it is recommended that you contact a professional locksmith or a Ford dealership for assistance. They may be able to help you get a replacement key or repair the anti-theft system to allow you to start the car. It is important to follow proper procedures to ensure the safety and security of yourself and your vehicle.
2answers
How can I start my 2008 Pontiac G6 if my ignition is not in and the anti theft system is active
You can't. You have to fix the problem, not find a way around it. The anti-theft system is there to stop exactly what you are trying to do.
2answers
Changed steering column on 2007 impala and now I have no crank no start. No fuel to injectors.
Your anti theft system isn't allowing it to start because you no longer are using the factory key. Contact someone close to you that does remote start instalations, they should be able to bypass the security system.
Engine wont start alarm lockout on 2004 buick rainier
Sallie, may have to have security reset at the dealer if you can not do it yourself. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Passlock III reset procedure reset security system on chevy buick...
Anti theft Alarm System Vehicle Security Keys Doors and Windows Buick...
Do It Yourself GM Security bypass
Won start Anti Theft Ignition Switch
2answers
2002. Why is anti-theft light on, preventing it from starting?
The most common cause is the chip in the key does not match the security code, or the security module has failed. The chip in the key must match the factory setting to allow the car to start.
If it worked before you replaced the lock cylinder, you need to have a new key with the same old chip cut to the new lock.
3answers
How to disconnect 2001 ford windstar anti theft
You need a bypass kit from Ford. Otherwise just disconnecting the harness will not allow the car to start.
99 ranger won't crank, periodically, has anti theft.
I looked at your security system, it is starter motor disable and fuel injectors. You can usually get the starter crank, but, if it is the security system, it still won't start because of fuel injectors. I don't know any way to bypass security system. You can check for applicable trouble codes, if there are any?
1helpful
2answers
89 firebird anti theft code won't let car start
If code 53 involves the PASS system for your car, the chip in the key has failed, or the sensor in the lock cylinder, or the control module.
The anti-theft system disables the starter and the fuel injectors. You could bypass those circuits to get the car started.
My car is not responding to remote key not starting when i try to start
Sometimes the original anti theft system put in by GM can cause a no start situation. The key needs to communicate with the ignition and then the ignition communicates with the TDM computer. (Theft Deterrent Module) The TDM then allows the car to start. When installing remote starts they tend to "bypass" the key ignition part of the security system. This will then eventually ruin the TDM. If you see a light on the dash that says SECURITY, then this is 100% your problem.
This link has info and some ways to fix this problem. http://vatspasslockpasskeysecurityhelp.yolasite.com/
Top Volkswagen Experts
ZJ Limited
ZJ Limited
Bradley
Bradley
Thomas Perkins
Thomas Perkins
Are you a Volkswagen Expert? Answer questions, earn points and help others
