My Miele dishwasher had a kinked hose. I found out when water started running down into the basement. I unkinked it. Now, it starts fine, goes through the first prewash cycle, then the light flashes and it just hangs up, before draining the water. I know the drain is working because it can't start to begin with until it drains the water out.
Any thoughts?
SOURCE: Miele Novotronic dishwasher G841
I asume U R talking about the Drain Hose?? As long as it doesn't get Kinked, I see no Problem.. I installed one yesterday the (25th) and the Drain comes out under the Dishwasher, so therefore, the Drain Hose has to be ran under the Unit.. No Problems !!! I hope this Helps U out...
SOURCE: Cycle starts then stops and Intake/Drain light comes on
Hey All.
I had the same problem with my Miele g843, and i finally got to the root problem.
My machine would drain ok, and fill ok, but when it tried to start a cycle, it would do nothing. I could hear a relay occassionally clicking until it finally gave up and signalled the blinking red light of death.
I first checked the inlet filter, drain pump and drain pipe but I discovered no obstructions. So I started taking the dishwasher apart, and discovered that the main pump was seized! This may not be the source of YOUR problem, since it could be many things, but this worked for me. Here are the instructions to remove the pump and get it moving again:
Pull out the dishwasher and disconnect the power, water and drain lines.
Empty all water from the unit (disconnect drain line and let the water drain into a low profile container) you may have to elevate the unit and tilt it rearwards to get the remaining water out.
Remove the side panels of the machine.
Lay the unit on its side elevated about 2-4 inches above the ground (be careful you don't put direct pressure on any of the internal components when you support it)
Remove the 4 screws that hold the base panel to the frame of the machine.
You can now see the motor.
Disconnect the electrical connections to the motor and the pressure sensor.
Disengage the clamps that hold the rubber hoses to the motor and slide the hoses off the motor.
Unscrew the single bolt that holds the motor inplace on the back panel of the machine. Pry the rear panel out slightly to release the dowel pins and gently pull the motor towards you (pivoting on the inlet grommet). Once you have the motor out, you can try to manually turn it by rotating the impeller. If it is stiff, you could have the same problem mine had. Using silicon spray with a nozzle extension, spray the seal between the impeller housing and the motor and continue to spin the motor manually until it becomes free spinning. If this doesnt work for you, you may need a new motor ( i never priced one out but it cant be cheap ).
If you get stuck somewhere email me and i can send you pictures: vector006 at hotmail dot com
Cheers!
SOURCE: dishwasher stops after 10 minutes inlet/drain light flashing
I had the same problem on a 5 year old model. It was the main pump leaking from a perished seal causing the water protection microswitch to trip. This gives the symptoms you describe exactly. Parts cost from Miele was about £60 for a new seal. Fairly easy to fit.
SOURCE: Miele G 7856 Commercial Dishwasher
Hi. The above machine stops mid cycle and drain/fill light is on, also
error code F3E, have cleaned both hot and cold water inlet filters, also
checked drain pump and drain line, all ok. Machine drains with no
issues and fills with hot water, runs for a while then shuts down.
Any ideas?
SOURCE: Intake/Drain lit flashing
I have exact same symptons, please someone help. I have had issue before where the plumbing backed up so it overflowed into the catch tray. Then that has to be vacummed out and then just start a new cycle. This time there is no water in the overflow tray....
