Recording your greeting
message
1 {MENU} i {#}{3}{0}{2}
2 {V}/{^}: "Yes" i {SELECT}
3 After a beep sounds, hold the
handset about 20 cm (8 inches)
away and speak clearly into the
microphone (2 minutes max.).
4 Press {STOP} to stop recording.
5 [off]
Hi There,
Press the Menu button
Use the volume up/down buttons to navigate to 'Answ. Setup'
Press OK
Use the volume up/down buttons again to get to 'Record greeting'
You might need to press OK here, I'm not sure.
Press the Start key and record your greeting
Specify the model of your answering machine from the list beginning at
http://www.uniden.com/owners-manuals/dect-phones/scat/dectphones_mnl/ to get the manual.
Which model phone do you have? For the CL82509 and related DECT 6.0, you need to set the outgoing message from the handset when the answering machine is on. (It can be turned on from the handset).
For the outgoing message: with the handset in Idle mode, press Menu/Select. Use the up (Dir) and down (CID) arrows to highlight Ans Sys Setup. Then press Menu/Select. Use the same arrow keys to select Announcement and press Menu/Select again. Press 7 to record a new announcement. At the tone, speak your message clearly then press 5 when you have ended the message. The message will play back.
Since you neglected to specify the model of your VTech DECT 6.0 system I can only suggest you enter it into the search box here to download a copy of the manual.
hi, if you want to record outgoing message on Answer of BINATONE FUSION 2210 DECT
phone, his the step you will follow. to turn A/M on press R then 5. to turn A/M off press R then 6. if you want to record Outgoing Message, press R then 1. After beep record your
message. Press 0 when you have finished your message, then C to return
to standby mode.
To listen to incoming messages, press R then 8. New messages are then
played back. Press 4 to delete message. thanks for using fixya
Can you give the exact model of your Philips Answering machine? Usually, long press and hold the #4 button to record a new outgoing message after the beep.
Well, your machine might be broken, or you haven't set the little switch on the unit to ANS.The switch is on the side of the machine where the cables come out.But here are the instructions from the manual:
Recording Outgoing Messages:
Your answering machine has a built-in outgoing message, "Hello, please leave a message after the tone."You can use this message or record your own.
1. Hold the ANNC/DAY/<<, and speak clearly into the microphone, no more than 10 inches away.
2. Release the ANNC/DAY/<< when you finish.Your answering machine beeps and automatically plays back your recorded message.
*Your outgoing message must be between one and 60 seconds.
*If you record your won message but wish to revert to the pre-recorded message, press DELETE during playback of your outgoing message.
