A lens error restart camera message would mean the camera just needs to be repaired. Something happened with the lens on the camera. A site that is excellent for help with the powershot models is www.camerasandparts.com All they work on are the Canons and they are not expensive at all. Your lens error repair thing is right on their site for the SD850. Hope that helps, that's where many go for help on these cameras, they're great for the powershots.
It may be possible to insert a feeler gauge or better yet crisp flexible plastic in around the three parts of the lens barrel. Maybe that will let you get under whatever gigantic clod of grit is wedging the lens tight. The smallest, inner ring(for the part of the lens that extends out the farthest from the body) is only 8-10mm deep and the next two are deeper.
After trying that sort of thing, as well as general beating and assorted ways of turning on multiple buttons etc our SD850IS still wouldn't open. We pulled the outer ring off by slipping a feeler gauge in and around it to release the adhesive. Twisting the next 'cap-ring' (round with the semi rectangular opening in the center) counterclockwise released it and exposed the two lens covering flaps. I took one flap out to have an intact one left to compare too. While I did take them out, what worked was prying the lens out by one of the little bosses, the nub, that held the cap-ring in. It responded to a moderate pull.
Maybe the speck I saw on the barrel was the culprit. In any case I wiped it clean and reinstalled the battery. It has now cycled properly with the battery reinstalled and is working again.
p.s. the springs on this model are different than what I saw on the article about the A1000. The spring wraps around the pivot post. Before pushing the flap all the way down on the pivot post you will want to catch one end of the spring arm on the post that drives the flaps to open and close. You may hold the end of the spring with a toothpickk to hook it over the post or you may catch the post by twisting the flap a millimeter extra before pushing it all the way down on the pivot post.
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.
Use
these at own risk as it may further damage the camera.
Firstly ,
try connecting your ac adapter or usb cable.
Try holding the
shutter button while switching on the camera.
Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).
Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
Other than that , I would take the camera to a repair
center for a evaluation to see if it would cost more to repair than to
replace the camera.
If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope
the advise is useful. please do not hesitate to let me know if you need
any further assistance. Also, please be so kind to let me know if you
found this helpful.
Regards
Andrea
SOURCE: Canon SD 850 says lens error,
I bought a canon SD 850IS before 15 months back and now i'm getting "LENS ERROR". I didnt damage by dropping down or handling roughly and also i didnt used much.when i start my camera it showing LENS ERROR.... Is there any way to fix this issue by my self or should i take to canon service center?
Please help me....
Thanks in Advance,
Srinivasan.G
SOURCE: lens will not close
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
SOURCE: lens error restart camera but
Hi
Your
lens is defective needs to be cleaned, repaired or replaced. If you got sand in the gears it will definitely jam up the lens! Sometimes you can tear down the lens and clean out the sand, and if none of the gears are damaged the lens will then work properly again.
There are online places that will do it for a
decent price and there are others that overcharge by way too much.
I know this because I OWN ONE that charges a reasonable price to do the
repair! (Google 'darntoothysam')
Just let us know if we can help! Good luck from
Darntoothysam com
Thomas
SOURCE: lens error , restart camera
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
SOURCE: When I try to turn on my Canon PowerShot SD850 IS,
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
